ccw fitment questions
Old Feb 6, 2012 | 12:28 PM
gt35R_evo's Avatar
Hello i don't feel like flipping through the "stanced" thread to find some fitments, so im looking for ball park spec's you have to run for 18x10 or 18x9.5 so with that in mind i appreciate any and all info that gets posted thanks for your time
Old Feb 6, 2012 | 12:49 PM
Im no CCW expert but they are too aggressive for my stock body
Compare what youre running now with your proposed set-up & it will let you know how far you have to go.
Ive been using these calculators
http://www.rimsntires.com/specs.jsp
http://www.willtheyfit.com/
Old Feb 6, 2012 | 09:28 PM
luckybull's Avatar
Just call CCW. they will tell you what you need when you tell them what you want.
Old Feb 7, 2012 | 12:13 PM
kovs04sti's Avatar
That ^^^
Old Feb 7, 2012 | 12:19 PM
AlwaysinBoost's Avatar
I had a set of 18x10 CCW's and 18x9.5 CCW's with 285/30/18s. Both fit fine because CCW knows what the wheel measurements need to be in order to fit those kinds of sizes on an EVO. Call them up and tell them your plans for the car and they'll make a set of wheels to your exact specs.
Old Feb 7, 2012 | 12:31 PM
Vivid Racing's Avatar
CCW wheels are built to your exact specs. They'll help you figure out what you need if you're not sure.
Old Feb 7, 2012 | 03:16 PM
SmurfZilla's Avatar
Dan at CCWheel knows EXACTLY hat it will take to fit 18X10's on the stock bodied evo.
You can forget about rotating your tires though
Old Feb 7, 2012 | 03:25 PM
dsmnine's Avatar
here are some pics of my old lm20 18x9.5 but like everyone has said call ccw they will fit it to the exact spec u need.
Old Feb 7, 2012 | 03:28 PM
Anarchy99's Avatar
Dan at CCW FTW
Old Feb 7, 2012 | 03:31 PM
EvoJoeIX's Avatar
whys that?
Old Feb 7, 2012 | 03:34 PM
dsmnine's Avatar
Originally Posted by EvoJoeIX
whys that?
front lip is 2 1/2 "
rear lip is 3"
IIRC
Old Feb 7, 2012 | 03:38 PM
EvoJoeIX's Avatar
i never noticed they were different. thanks
Old Feb 7, 2012 | 04:31 PM
not so.
I had a square 18x10 setup. This wasn't for a show car, though, so I didn't care about low or staggered offset. My concern was for even tire wear.
Old Feb 7, 2012 | 04:36 PM
R/TErnie's Avatar
18x10.5 CCW classics. OEM body. I win
295/30/18 R888's
People generally go for too low of an offset in the rear because they don't think outside the box. LM20's clear calipers better than classics.
Old Feb 7, 2012 | 05:14 PM
forc3 f3d's Avatar
absolutely perfect set up there!! are you still using all the tricks like you were with the RPF1's?
