Trying to fit 18X10 wheels
Old Mar 16, 2012 | 07:52 PM
IX_MR's Avatar
I want to put 18x10 XXR 521 wheels on an Evo 9. What modifications would I need to do other than rolling the fenders? Here's a couple pictures to show you what I'm going for...
And are these good wheels? What are your opinions? Thanks
http://i100.photobucket.com/albums/m..._1355335_o.jpg
http://distilleryimage1.s3.amazonaws...381b65e3_7.jpg
http://distilleryimage5.s3.amazonaws...3815112c_7.jpg
Old Mar 17, 2012 | 10:24 AM
mr0072003's Avatar
Nice wheels man, but rolling fenders or mjor body work is theonly thing I can think of.
Old Mar 17, 2012 | 10:37 AM
EVOIXNooB's Avatar
You are gonna have to seriously roll the fender lips and have some serious fender pull done... which is never perfect.... or you can trade it in for a X and fit it easy...
Old Mar 17, 2012 | 10:55 AM
llDemonll's Avatar
the second and third pictures there are DecepticonsMR's car so you can ask him what offset and fender work he did.
afaik he didn't do much aside from rolling fenders. rears might be pulled a bit but (unless it's changed) the fronts aren't spaced out with the fender mod or anything
Old Apr 3, 2012 | 02:11 PM
ApexEVoIX03's Avatar
In for some more answers because searching the stanced thread is a PITA lol
Old Apr 3, 2012 | 04:19 PM
pignosesr's Avatar
Im running the same setup. Need 25mm spacer up front to clear brakes. Currently I have zero fender work running 235. Had it pretty low, rubbing when turning fast, big dips or had people in the car. But keep in mind i have no fender work done. YET Oh and youll need coilovers as well. Goodluck!
Old Apr 3, 2012 | 04:36 PM
kbuss's Avatar
Get the right offsets and you wont need a spacer to clear calipers. You need coilovers, you will most likely need a roll depending on the size tire you plan on running. I have 18x10 +19F +32R, I don't need spacers, to clear anything. I'm running 265/35 tires and a roll w/ some camber is all i need.
As far as your question on if they are good wheels....if you've seen my other posts you will know how I feel about XXR.
Old Apr 3, 2012 | 04:38 PM
mileb's Avatar
Can anyone post a pic of they ride with a wide rim? I want to check out the rides overall stance.
Old Apr 3, 2012 | 04:45 PM
kbuss's Avatar
Search "The ULTIMATE Aggressive Wheel Thread"
Old Apr 3, 2012 | 04:51 PM
eric6's Avatar
18x10 +15 with 235's
Old Apr 9, 2012 | 12:43 PM
dont want to thread jack but 18x10 521's on an 8/9 can you run a 265 tire?
and to OP i know you also are suggested to hammer the pinch welds
Old May 19, 2012 | 06:06 PM
9990123's Avatar
Do u need any spacer at front or rear??
Old May 19, 2012 | 08:40 PM
IX_MR's Avatar
Thank you guys... I think I will pick a less aggressive setup
Old May 19, 2012 | 10:06 PM
importmachine's Avatar
is it bad to to the drivetrain to run wheels with same size but different offsets like Kbuss is?
Old May 21, 2012 | 05:30 PM
xceler8rob's Avatar
I'm running 18x10 et25 with 255's all around. Slight roll in the rear and on coilovers.
