will this wheel setup look good with swift Spec-R springs??
Old Apr 1, 2012 | 08:49 PM
IX_MR's Avatar
i want to have the same setup as the car in the pictures below but i want to have the swift spec-r springs instead of coilovers. will the car still have the "stanced" look or will it be too high?
The wheels are: Varrstoen ES 2.2.1 - 18x10.5 and +15 offset. the tire size is 235-35-18. i don't know the camber though.
but i think i will get wheels in the size of 18x9.5 or 18x10 or what size should i get? and what offset?
here are the pictures:
http://www.sntrl.com/wp-content/uplo...VOfeature8.jpg
http://www.sntrl.com/wp-content/uplo...VOfeature5.jpg
http://www.sntrl.com/wp-content/uplo...VOfeature7.jpg
http://www.sntrl.com/wp-content/uplo...VOfeature4.jpg
http://www.sntrl.com/wp-content/uplo...VOfeature2.jpg
THANKS
Old Apr 1, 2012 | 08:56 PM
Blue91lx's Avatar
For a functional 18x10.5 setup, go with something around a +35 offset.
Edit: Just noticed you're not on coil overs. Well, you need em' to run that big of a wheel. You'll probably need to run a 6" spring as well. Just search a little bit. All the info you need is on here.
Old Apr 1, 2012 | 08:59 PM
IX_MR's Avatar
but what about the gap between the fender and tire? look it look too high with the swift spec-r springs?
Old Apr 1, 2012 | 09:00 PM
IX_MR's Avatar
will*
Old Apr 1, 2012 | 09:01 PM
jdmEviL8's Avatar
ur gonna need coilovers to be stanced maing
Old Apr 1, 2012 | 09:04 PM
Blue91lx's Avatar
You can't even run those wheels with conventional springs, so what does the wheel gap matter?
Old Apr 1, 2012 | 09:05 PM
evotuner04's Avatar
15 Year MemberLikedLoved
that thing is sexahhhh
Old Apr 1, 2012 | 09:10 PM
IX_MR's Avatar
Why not?
Old Apr 1, 2012 | 09:20 PM
Blue91lx's Avatar
Because the wheel will hit the spring. Not enough clearance. It'll hit the rear trailing arms too.
No more help. Every answer you need is in this thread:
https://www.evolutionm.net/forums/ev...vo-thread.html
Old Apr 1, 2012 | 09:47 PM
stpkenton's Avatar
, i am usualy the one to help all of the fitted guys, but you really must use a search button.....hell just search my name!
Old Apr 2, 2012 | 08:48 PM
a4rontran's Avatar
spacer and roll fenders might do it.
Old Apr 2, 2012 | 11:14 PM
sujinX's Avatar
really dude? gonna need a lot more than just rolling fenders with that spacer idea.
OP- if ur not going to listen and not gonna search. try it and see what happens. those wheels look really good but they are rather heavy. but it looks like your just into looks.
Old Apr 2, 2012 | 11:29 PM
Sidnakit's Avatar
why does the driver door not line up with side panel?
Old Apr 2, 2012 | 11:43 PM
Lukelis's Avatar
maybe its a little bit to wide, but looks good
+1 for coils
Old Apr 3, 2012 | 02:24 AM
IX_MR's Avatar
I'm searching and trying to figure out how to do this guys....
