will this wheel setup look good with swift Spec-R springs??
he is running a fender mod to fit the wide wheels without a lot of fender work. evodave used to sell these fender mods, just brackets and spacers.
coilovers is the way to go with those wide wheels. listen to the guys above who actually have wide wheel setups.
u wont find an evo "stanced" with 10" wide wheels running stock struts and spec r's.
You can't run wide wheels unless you have coils.
If you wan't to run 10" wide you are fine with the spring that come on coilovers.
But if you plan on 10.5" or wider you WILL need a shorter spring.
Roll/pull is a must.
Goodluck!
Goodluck!
sir-rice-a lot.
yo, dude. check out my wannabeithinkiam wheels with these oem width tires. so sick. i can get rocks stuck in between my tire and wheel lip, and my tire can slide back and forth along my wheel going through turns... sometimes they spark. so awesome.
-Jalal
-Jalal
GarageLine.com
EvoX 'For Sale' Wheels / Tires
159
Nov 15, 2016 04:57 PM
Bruzewski
Aug 6, 2014 06:53 AM
Kami Speed
Evo 'For Sale' Wheels / Tires
106
May 20, 2014 08:46 PM
