evo ix dash scratch repair
I screwed up taking my cd player out and got some little scratches in my dash which really bothers me. How to i go about getting these scratches out? Whats the best options available
some interior upholstery shops can possibly help, or if its impossible to repair they can re-cover your dash with some leather or alcantara.
Depends what you scratched. The textured surfaces are hard to match. 2000 grit sand paper wont do it. If you scratched the radio bezel, just replace it- they are 35$ new. If you scratched the actual dash there are special texture its you can buy but i don't know you will make it unnoticeable. You could always consider covering the dash with suede or flock it.
Is the black textured dash part to the left of the silver radio benzel. Its not a deep scratch or very very noticable, its a couple fine scratches. I have no idea how it got scratched since i was very careful taking out but the damage is done. I know im not gonna be able to make it dissappear completely, but anything to make it better would help. The hair dryer fix its just to risky it seems to try, probably cause more damage trying it that way
thats for cracks in the dash, not scratches
I work at Toyota and sometimes these things happen. If they are light scratches what I do, and I know this sounds stupid, but take the black cap off a regular sharpie marker and use the tip of the cap to lightly rub on the scratch. It will smooth down the scratch and basically blend the scratch color back into the dash without messing up the grain since the cap plastic is softer. It won't completely eliminate it but it will minimize it to the point of not noticing. It works on lighter scratches, not deep ones, and takes a little patience/practice to do it smoothly, but it works.
Your stuck with it my friend. Some people have tried using heat guns to blend the color, but in my opinion you'll just make it worse. Replace dash, or put a sticker over it
