Front Splitter beneficial for Dragracing?
Old Oct 15, 2012 | 11:39 AM
Randal's Avatar
Guest
As from what I have read it prevents front end to climb up and it basically adds downforce to the front end while at high speeds. So if I am right it's good for a course and not well for Dragracing since it adds weight to begin with and also adds dozens of pounds at drag racing speeds?
Old Oct 15, 2012 | 11:44 AM
boosted91t's Avatar
Does it create drag? If the answer is yes, then it probably would not make sense
Old Oct 15, 2012 | 12:44 PM
Randal's Avatar
Guest
Totally makes scense and i knew the answer but i wanted someone to prove me wrong Now i am going to have to temove the APR one i have installed and have to figure out what to do with the two bracket holes ontop
Old Oct 15, 2012 | 03:47 PM
TigOLDBiTTies's Avatar
it depends on the setup, if i was going 160+ id rather have a little downforce for some stability at high speeds. if i was driving around in a car going 120-140 then id get buschur racings flat bottom front splitter and flat rear. they reduce drag and dont create any downforce.
Old Oct 15, 2012 | 04:33 PM
GTijoejoe's Avatar
I don't see it being beneficial for drag racing. There's a reason drag cars have skinny FR tires... its not for stability.
Old Oct 15, 2012 | 06:41 PM
sujinX's Avatar
Not beneficial for drag racing. Any downforce mod really. Trap higher speeds with no wing some have proved.
Old Oct 17, 2012 | 07:08 PM
boosted91t's Avatar
It all adds up. I went as far to remove wipers, mirrors, rear wing and tape up all cracks in the front end. Made up the small amount I needed
Dragracer187
399
Oct 1, 2012 11:40 AM
Dragracer187
Oct 5, 2011 04:11 AM
Dragracer187
Apr 3, 2010 01:58 PM
Dragracer187
Apr 21, 2009 06:49 AM
Dragracer187
10
Oct 27, 2008 06:44 PM
