DIY Overflow Fabrication
Old Jan 25, 2013 | 12:45 PM
evokid511's Avatar
Originally Posted by Anarchy99
No you are incorrect, it sucks it back into the radator also. It is not a one way out system.
I understand that part, it was left out in my post by accident, but yes it does require a tube to run to the bottom to pull water back into the Rad as needed
Raptord's Avatar
Originally Posted by evokid511
the overflow does not go back to the radiator?? it is incase the level gets to high in the radiator it can push the excess water out which gets pushed into the "overflow" then when the overflow gets to high it dump that water onto the ground via the overflow hose, go look at your stock one... so yes i actually can have an overflow without going back to the radiator but will need to create a dumpe tube exactly like what STM did in theirs...
The overflow system is 2 way... when the coolant expands in the cooling system, some of it gets pushed to the overflow. When the temp comes back down, that extra fluid in the overflow needs to get sucked back into the main cooling system.
Originally Posted by xtruemassacre
only way to do it...don't need to waste time fabricating. Unless that's what you're into.
That's the idea... He said in the OP he's interested in making his own.
Old Jan 25, 2013 | 12:54 PM
xtruemassacre's Avatar
I get that. but like another member said, cost and time ratio doesn't really make it worth it. I can understand exhaust parts, roll cages, etc. but for $100+ and three days of shipping, one can be bought and installed in the same time imo. BEST OF LUCK to the thread originator in getting one fabbed up.
Old Jan 25, 2013 | 01:07 PM
evokid511's Avatar
I would completely agree with you if one didn't have any idea how to fabricate things, or have an understanding on how things worked. but in my situation having mig and tig welders, aluminum readily available and taking maybe a few hours out of my day why would I wanna waste my money to buy something?? It realistically would cost maybe 60-75 bucks and would have almost an identical piece as STM sells for 150 plus shipping???
For me fabricating is the fun part of owning a car like this, being able to make and try new things is why I got an Evo, it's always being pulled apart to change something or try something new, guess that's why I like to make things not buy them when I can...
Old Jan 25, 2013 | 01:24 PM
boosted91t's Avatar
Vibrant
Old Jan 25, 2013 | 03:26 PM
Extreme Dimensions's Avatar
subscibbed to see the finish product.
Old Jan 25, 2013 | 08:50 PM
GTijoejoe's Avatar
Yes exactly, which is why the Jose must run to the bottom of the tank, and if you could find the other site that would be awesome, thank you!
I'm on it, I had to go ask for help because I lost the site... so hopefully my buds come through. I know it exists, I even think they have that exact cap used.
Update:
http://sdhqoffroad.com/weldinbungandcapassembly.aspx
http://pitstopusa.com/i-5073722-pro-...-o-d-bung.html
http://www.deucerodparts.com/oil_filler_caps.html
http://secure.chassisshop.com/partdetail/C73-739/
Old Jan 27, 2013 | 05:31 PM
Joshthree6three's Avatar
STM ships for 3-4 dollars on all orders in the US I believe.
Old Jan 28, 2013 | 10:06 PM
Lob's Avatar
Lob
and maybeeee another 30 bucks on some aluminum
IMHO, they are stainless, at least those by stm
if that changes something
Old Jan 29, 2013 | 06:53 AM
GTijoejoe's Avatar
Are you 100% on that?, usually they are always aluminum, and those don't look like stainless welds.
Old Jan 30, 2013 | 05:33 AM
AngryEvo8's Avatar
Exactly I believe they are aluminum as well. Look at how its polished it would be hard to make stainless shine like that.
Old Jan 30, 2013 | 08:44 AM
DSMpsi's Avatar
Originally Posted by STM
"Welded Aluminum Body"
You can polish stainless to a mirror finish, but the reservoir in question is definitely aluminum.
Old Jan 30, 2013 | 09:15 AM
Canadian-Ix's Avatar
Built not bought! Fab it up and post pics, ive been thinking of doing all my own reservoirs lately too. Happy fabbing OP!
Old Jan 30, 2013 | 03:08 PM
evokid511's Avatar
my thoughts exactly just needs to be done right.. i will be on vacation the next week so unfortunately will have to wait till i get back to get it fabbed up
Old Jan 30, 2013 | 03:11 PM
Babs's Avatar
Originally Posted by MRolla
Just spend the money and buy there by the time your done fabricating it would have cost the same. Just my 2 cents
Some people like to do things themselves...it reaps a greater level of satisfaction in the end knowing you made something.
Try it sometime...
EDIT: Hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii Sean
