PlastiDip on a sanded wing?
Old Mar 7, 2013 | 05:15 PM
fafaforza's Avatar
My wing was faded, I sanded it down a good deal, but it still needs work before a clearcoat. So I was thinking I might put some black plastidip just to see if I'd like driving with the wing. I bought the car with it faded and have always driven it wingless (first car too).
So who reckons that I would have trouble peeling the PlastiDip off sanded CF and I shouldn't bother?
Old Mar 8, 2013 | 10:35 AM
ikt's Avatar
ikt
Go for it. You can use SEM Solve on plasti-dip and it will literally wipe off like dirty water.
Old Mar 8, 2013 | 11:23 PM
matrho2792's Avatar
As long as you spray on a thick enough coat of plastidip, usually about 4 good coats or more, it should peel off no problem. I've only had problems getting the thin coats off as it usually peels off in small pieces. Also if you have any problems getting it off, you could always just pressure wash it too.
Old Mar 9, 2013 | 06:41 AM
fafaforza's Avatar
Cool, thanks. Will give it a shot.
Old Mar 9, 2013 | 09:58 AM
ikt's Avatar
ikt
Don't pressure wash it, you could peel your paint off. Use SEM Solvent.
Old Mar 9, 2013 | 04:52 PM
matrho2792's Avatar
Pressure washer would of course be a last resort. You don't have to get but 2-3 feet away from plastidip to wash it off. I've personally pressure washed it off before more than once with no problems. You should post up some pictures of the finished product
Old Mar 10, 2013 | 01:11 PM
El Guapo's Avatar
He is Correct
SamFQ340
Apr 6, 2014 06:42 PM
kosteniuks17
Mar 19, 2014 09:19 AM
mel1888
Dec 17, 2013 11:50 PM
PCToolsWiki
Nov 8, 2010 11:04 AM
