Emblem
Old Aug 2, 2013 | 10:07 PM
J!n K@z@mA's Avatar
Emblem
Got tired picking out the wax that gets in between the letters of the EVO8/9 Lancer emblem. Bought the EVO 7 "Lancer" emblem. Problem solved.
Later that day...
Now, I'm adjusting the swaybars to induce more oversteer to eliminate my low speed understeer issue. For better or for worse, we'll see tomorrow if I can handle the car better or not. Keep in mind, I drive 50miles everyday to work and back. That's not including other errands so I run All season tires (no performance grip).
Old Aug 2, 2013 | 11:57 PM
TigOLDBiTTies's Avatar
where did you get the emblem from, it looks good.
your line needs alot of work to say the least, and although it does understeer if you had used more of the course it wouldnt be as bad.
adjusting the swaybar can also only do so much getting a tre diff or reassembling your clutches in the rear diff would fix the problem and make you slide the rear around alot easier.
Old Aug 3, 2013 | 12:18 AM
J!n K@z@mA's Avatar
I already rearranged the clutch plates of the rear.
I'm working on fixing the driver and adjusting the car to find the balance between the driver and the car.
domenictoretto
Mar 19, 2016 04:03 PM
rogerlam
Jan 4, 2016 08:45 AM
mrwickd123
Sep 13, 2014 11:44 AM
steffy27
For Sale - Cars For Sale
Sep 13, 2012 08:40 AM
threepointsix
Jul 4, 2005 11:31 PM
