2005 evo 8 electric blue-> Iceland
Old Apr 9, 2014 | 07:25 AM
brusinn's Avatar
wanted to share my car here with you guys, great forum, have got alot of great information from you guys!
bought the car in november 2012, the mods were then 3'' exhaust and downpipe, invidia o2 housing, CAI and tune.
the front shocks started to fail so i bought bilstein shocks from evo 9
first thing i had to do was change the timing belt, and seals for the transfer case, was leaking pretty bad, i saw that the small o ring was missing from the previous owner when he replaced the clutch.
the car needed new tires so i bought nitto 555r
then i wanted to start tuning it myself, so i bought innovate AFR, and tactrix cable.
then the clutch started to shutter heavily!! i bought new clutch and flywheel.
sandblasted some parts while i was on it.
and paint
at this time i was starting to map the ecu myself, flashed no lift to shift from tephra. worked very good !
now i wanted some more power ! so i got a great deal of gsc s3 cams
now im upgrading my turbo, got 3071 billet wheel, td06 shaft and new hotside, and i machined the compressor cover to match the wheel. also im taking out the internal wastegate and modding it to external wastegate.(thanks turbolab!)
my friend is building new o2 housing for the external wastegate with dump.
like this.
turbo is ready !
i bought tial watercooled wastegate for the external setup
my main focus is to build a track/dd car, will also go to the 1/4 mile and check the what time i will get ! when i bought the car, my best 1/4 was 12.7@108mph
what do you think ?
thanks!
Old Apr 9, 2014 | 10:41 AM
Atrophical's Avatar
Wow! This car is looking amazing and its good to see someone so in depth with a new purchase and fixing everything correctly!
Congrats!
Old Apr 9, 2014 | 11:02 AM
rjfg's Avatar
Wow great work!
Old Apr 9, 2014 | 11:50 AM
Ev0ikon's Avatar
Awesome!
How much does the machining job on the cover cost you?
Hype's Avatar
Lovely car! Great write up! Can you share more info on the turbo modifications?
Old Apr 9, 2014 | 12:11 PM
brusinn's Avatar
Originally Posted by Ev0ikon
Awesome!
i got it for free, my best friends dad owns a machining/weld garage
but turbolab can do it for some price, dont recall how much.
thanks!
specs on the turbo
stock evo 8 compressor cover(machined to fit wheel specs)
Tdo6h4 turbine housing
Tdo6h4 shaft
Billet 3071 Compressor wheel
Rebuild kit
Old Apr 12, 2014 | 04:06 PM
brusinn's Avatar
here is the o2 housing that my friend built
Old Apr 13, 2014 | 08:06 AM
jrainwater's Avatar
That looks nice. I assume you're going to install a dump tube on the bottom of that ewg? Edit, Nevermind I saw a couple posts up nice
Old Apr 21, 2014 | 09:40 AM
brusinn's Avatar
video i made, started to put 11.6psi wastegate spring, but there was massive boost creep, was seeing 18 psi in 3rd gear, so i put 8.6psi wastegate spring in the wastegate and its boosting 12psi in full boost, so i think next step is take the turbo out and port the gate were the internal flapper was so the wastegate can flow better, think that is the problem, it isnt opnening fully.
really like the power of the 3071 turbo.
Old Apr 25, 2014 | 03:20 PM
brusinn's Avatar
looking forward to 1/4 !
still on stock injectors! pretty much maxing them on 16psi, but pretty safe yet, never lean on the top end.
Fastrax04
11
Dec 18, 2015 08:56 AM
LVSBB6
For Sale - Part Outs
Feb 19, 2015 07:18 PM
Miasma987
14
Sep 12, 2014 06:11 AM
prowakeskater
Evo X Dyno Results
19
Apr 6, 2013 06:21 AM
Foxmaster
Nov 24, 2012 03:14 PM
