evo 9 bumper fitment issue
Old Jul 16, 2014 | 12:25 PM
mike_89's Avatar
Anybody else have an 9 front bumper conversion on their evo 8 with gap from up under the grill and hood, and also the headlights and bumper.
Ill post pic as soon as i figure out how to, but for those who know what im talking about right off top, how do i go about fixing this problem.
Old Jul 16, 2014 | 12:50 PM
Mistaken's Avatar
A pic would really help. Im pretty sure it should fit just fine.
Old Jul 16, 2014 | 01:12 PM
Sil'vr-Boi6's Avatar
This is a common problems from the conversion. Its likely OP is missing hardware on the Evo IX bumper. Half of the rivets, metal brackets, mesh, misc. cannot used from Evo 8 bumper to a Evo 9 bumper.
There is gap in my Evo IX bumper, I plan to put a double side tape on a piece of foam between the gap within the bumper. I dont have that problem in the grill.
Old Jul 16, 2014 | 03:43 PM
Mistaken's Avatar
Makes sense. I was assuming they had all the brackets and so on...
Old Jul 16, 2014 | 08:18 PM
flippymcbean's Avatar
I have a set of Evolution 9 bumper retainers. I pulled them off because I thought I would want a 9 bumper again, but I decided to hunt for an 8 bumper.
Old Aug 17, 2014 | 09:22 PM
mike_89's Avatar
Old Aug 17, 2014 | 09:23 PM
mike_89's Avatar
Gaps between headlight/bumper and hood/grill
No frame damage accident to front end.
Old Aug 17, 2014 | 10:30 PM
turbotalawd's Avatar
Re-install the front crash beam as it adds support.
Old Aug 18, 2014 | 02:26 PM
supaduckie8113's Avatar
+1 the crash beam should help with the gaps but pushing the bumper slighty forward and up
Old Aug 20, 2014 | 07:52 PM
mike_89's Avatar
Anybody knows if the evo 8 and evo 9 crash beams are different from eachother?
And if so, will i need to the 9 beam since i have the 9 bumper?
Old Aug 21, 2014 | 07:29 AM
Ev0ikon's Avatar
This.
Old Aug 21, 2014 | 08:35 AM
SSMCL9's Avatar
i have the same issue, you are missing a foam on the rebar that gives the bumper a little lift that should close those gaps. put the rebar back on and put something in between the rebar and the bumper
Old Aug 24, 2014 | 10:59 AM
drifthobo's Avatar
The foam actually makes a difference? I have issues with bumper sag also underneath the headlight
Old Aug 24, 2014 | 10:13 PM
Betty's Avatar
I have the same problem. I installed my 9 bumper on my Evo 8 and the bumper sags under the headlights.
Old Jan 22, 2015 | 07:32 PM
mike_89's Avatar
Just installed the reinforcement bar and i cant seem to get the bumper back on at all. I've taken the bumper off and on countless times, but this is the first time instaling with the crash beam on. I'll try taking my time putting the bumper on again when im not in the middle of something and rushing.
Any insight on why it was easier to put on without the crash beam than without? Is it that much of a tedious install with the bar on.
I'll take pictures of different angles when i get the chance if that helps.
