Ultimate Gauge Panel...
Old Mar 16, 2004 | 11:52 AM
Kaisho99's Avatar
Ya know that was actually A LOT easier that I thought it was gonna be.
Basically I just nudged my thumb from the back (there are holes throughout the stock panel that let light out) and pushed the stickers out a little then just worked carefully a flat head screw driver and lossened it all around. They came right off. And there was enough adhesive left on it to stick on the new panel.
They were much thicker than I thought so you would have to be real careless to rip one. Someone told me they ordered new onse instead of prying off the orginals like I did, so you have a back up just in case.
Hope that helps.
Oh, almost forgot. There are little tabs at the top of each sticker that fit into a little hole on the stock panel (makes for quick an easy alignment at the factory). So you have to snip those off with a scissors or something.
Old Mar 16, 2004 | 05:11 PM
RBMotoring's Avatar
I've got something that'll be something like this, but maybe not as bootyful. $60 takes the kit. It comes with the radio relocating thingy from Mitsubishi, and a 3 gauge cluster thing that'll put 3 52mm gauges in the stock radio location.
Old Mar 16, 2004 | 05:15 PM
CJK's Avatar
CJK
what sticky things are you guys talkin about?
Old Mar 16, 2004 | 06:08 PM
jerastan's Avatar
i think they're talking about the climate contol overlays.
Old Mar 16, 2004 | 06:15 PM
PnutButterWolf's Avatar
looking good! very nice!
Old Mar 16, 2004 | 07:00 PM
Eon's Avatar
Eon
Its gonna take another month for them to come out with another list....I defiantly want it.
Old Mar 17, 2004 | 01:08 PM
CJK's Avatar
CJK
What is the part number from Mitsu for just replacement stickers? Also, how did you get the climate control stickers to come off?
Old Mar 17, 2004 | 01:13 PM
SoR's Avatar
SoR
When I was removing my stock panel off, one sticker came off almost by itself. It's easy... they have like a small clip that attaches them to the panel and are also glued to it but the adhesive isn't very sticky so you can take it off easily.
Old Mar 17, 2004 | 05:42 PM
rACerS's Avatar
what size guages are those?
Old Mar 17, 2004 | 06:53 PM
CJK's Avatar
CJK
well, I am sure I will figure it out when I get mine...wish there were install pics!
Old Mar 18, 2004 | 08:13 AM
20k's Avatar
20k
Originally posted by XRS-Lift
looks good but its just not practical. Any guage placed outside of the viewable area is not a good placement. Its got to be right above the cluster, below it, or right next to it. You still have to look completely away from the road to look at those guages.
Defi gauges have configurable bright red warning indicators that turn on whenever a sensor reads too high (boost, EGT, oil t., water t.) or too low (oil p., fuel p.). You can also set up warning buzzers. It's easy to see the indicators out of the corner of your eye so it's no big deal. Craig's panel is also slightly tilted toward the driver which helps this.
Pics soon ...
Old Mar 18, 2004 | 08:32 AM
EVOlunchbox's Avatar
Yeah what he said
Old Mar 18, 2004 | 09:22 PM
Z1 Performance's Avatar
60mm gauges
and they look DAMN sexy !
Old Mar 19, 2004 | 10:54 AM
Novtec1's Avatar
Veteran: Army
damn that looks sooooooooo hot!!!!!!..... karash is about to do the same set up... can't wait to see what it looks like in person....
Old Mar 19, 2004 | 12:40 PM
johnjonfenomeno's Avatar
Seems like the climate control stickers are not illuminating at night. Does craigs panel have holes in the back to allow this? If not Im gunna have to carfully drill to allow the light to pass through
