A little color under the hood
Old May 27, 2004 | 07:56 AM
jid2's Avatar
I was looking to add a little color into the engine compart. Painted the intake, filterbox, cam cover, and plug cover silver. Then painted the Mitsubishi purple to match the grounding kit. Sometimes I thinkit looked better in my head, but it's starting to grow on me.
Old May 27, 2004 | 08:11 AM
siantjab's Avatar
I like it! What kind of paint did you use and how did you prep it?
Old May 27, 2004 | 08:52 AM
eclipsegs2k1's Avatar
looks pretty good, definitely a good idea. I think it might look good too if you were to get a polished manifold heatshield. Just a thought. Looks good though.
Old May 27, 2004 | 08:56 AM
jid2's Avatar
The paint was Rust-Oleum Bright Coat, metallic silver. It looked spray crome when it was wet and I almost died. I just cleaned the parts for prep, that was all. The purple was model paint, put on with a brush.
I plan on painting the header black, and the heat shield silver. That should look pretty solid I think.
Old May 27, 2004 | 06:54 PM
evo81's Avatar
okay
Old May 27, 2004 | 07:12 PM
exhaust_note's Avatar
it looks like that spray painted civic down the street from me....
w/e you think but i don't like it.... just my opinion....
Old May 27, 2004 | 07:14 PM
SirAragorn's Avatar
looks great!!!
Old May 27, 2004 | 07:26 PM
sr20det91's Avatar
Looks good. Get some polished inner cooler hoses dress up the heat shield and you'll be good to go.
Old May 27, 2004 | 07:27 PM
Mitchubishievo's Avatar
Would look better with different colors...not soo flashy ones I mean....
Old May 27, 2004 | 08:08 PM
SinCityEvo's Avatar
The paint will peel if you paint the heat shield. I polished mine to a chrome like shine just by removing the black paint and using Mothers aluminum polish. Also, polish the upper IC pipe. That shines like a mirror.
Old May 27, 2004 | 10:17 PM
marksae's Avatar
What did you use to remove the paint from the exhaust manifold heat shield? Yours looks very nice!
Old May 28, 2004 | 04:07 AM
Lightsped's Avatar
Same opinion from me.
Old May 28, 2004 | 07:58 AM
SinCityEvo's Avatar
Mark, I used a paint stripper, thinner, wire brush, emory cloth -- whatever I had in my garage. It took awhile, but once the black paint comes off, there is bare silver metal underneath. I then used Mothers mag & aluminum polish to buff it (tried others, but this works the best). The more you polish, the more the metal smooths out and the shine deepens. I ocassionally polish it on the car when I have time. It's held up for 8 months, just occasional water spots.
Another option is chroming it. Another member that I know had it done for $40 locally and it looks sick. Mine looks flat next to it.
Spoolin4g63
Sep 19, 2011 09:27 PM
evoballer
22
Jul 23, 2010 05:56 PM
Demon_ni2
Mar 2, 2010 09:32 AM
eddyk
10
Mar 14, 2005 04:23 PM
