Clear Coat on Carbon Fiber Rear Wing
Old Jun 14, 2004 | 07:38 PM
stanimal8's Avatar
Hi guys,
Just a FYI, the clear coat on the EVO 8's carbon fiber rear wing is not very "bird sh*t" (Yes, that's a technical term) resistant.
I had washed my car this Sunday, left it out in the sun for about 3 hours, I noticed the bird sh*t on the rear wing and move the car into the garage to let the paint cool off, and then I washed it off and found minor pitting in the clear coat!
With a lot of elbow grease, I was finally able to compound most of it out.
I would strongly recommend always having a couple of coats of good wax on the wing at all times.
Old Jun 14, 2004 | 08:27 PM
showoff's Avatar
The clear coat is thin on the wing. I had a body shop spray 3 coats of clear coat on the top part of the wing because it was already fading. Looks brand new again.
Old Jun 14, 2004 | 10:12 PM
johnnysixer's Avatar
Ive had my car for about 2 months now...and the clearcoat is really starting to **** me off. I'm **** about having my car clean all the time, and the weak *** clearcoat is not helpin me out. I'm thinkin of getting it re-clearcoated.
Old Jun 14, 2004 | 10:15 PM
NvsEvo's Avatar
instead of spraying it with clear coats.....try to get your car professional paint sealant done... a friend of mine owns a detailing shop, and did it for me......my car shines brighter than newer cars......just my .02
Old Jun 14, 2004 | 10:17 PM
NvsEvo's Avatar
im not too sure on what kind of sealent it is, but he told me its the same ones car dealership uses for and option
Old Jun 14, 2004 | 10:26 PM
WannaRace's Avatar
Last year right from the dealership floor they told me to wax it once a month, more if possible, and I have been with great results...
Old Jun 16, 2004 | 07:34 PM
Hmmm....paint sealant. How much did that cost you?
Old Jun 16, 2004 | 08:01 PM
AznFlip's Avatar
What I would do is:
Remove the current clear coat by sanding with 500-600 grit wet sandpaper. Then apply about 4 new clear coats (let it dry for 12 hrs or so) then sand it with 1000 grit, 1200 grit, 1500 grit. For the final sanding, use 2000-2500 grit (wet sandpaper) or 3000 grit until the shine comes out but be carefull not to sand it really hard cuz the original surface might get sanded. By the way, the sandpapers needs to be soaked on the water for about 15 minutes before using. Also, add a small amount of car wash shampoo. After sanding, let it dry and apply a rubbing compound to remove the blemishes or small cuts.
I think I have enough knowledge about this cuz I painted my body kit and I saved $$$$.hehe.
Old Jun 16, 2004 | 09:29 PM
kamokazi's Avatar
i may not have a evo, but my dad works for a dealership.... and has been for last 14 years.... for every car we have, instead of wax, we use a sealant.. its a silicon base... u use it like wax... works alot better and keeps it cleaner.
Old Jun 17, 2004 | 07:45 PM
where can I get me some paint sealant?
Glaz
12
Nov 7, 2016 02:01 PM
Bassicfun
Jul 11, 2016 03:23 PM
joeymac
Mar 28, 2016 02:38 PM
EvoEmperor4G63
Jan 7, 2006 01:28 PM
