Updated!! Custom Vinyl Overlay kits
Updated: Red Version out now!!
The smoked overlay kits are finished, and look amazing. You can find then here BlueBatmobile.com .
You can also get these smoked tails with the bottom turn signal cut out, if you prefer (I think look much cleaner).
Since the taillight template is done, the red out is soon to come. But there is still a problem of the reverse being redded. My idea of putting a smoke reverse would look kinda weird, so the only solution we could think of was to change the turn signal into the reverse and so forth. Well I'll update on the progress. Thanks for all the people who gauged interest in this.
Just to let you know I did the reverse light turn signal switch on my painted tail lights. All you have to do is cut off one piece of plastic on the turn signal light socket to make it match the reverse light one, then switch them. I have been running them for a couple months and it works fine.
Originally Posted by Creamo3
I am still down for a set of red tails and smoked headlights
It's good to see that the ball is rolling on this project though
.Bat™
Originally Posted by WannaRace
Let's see some smoked tails with the turn signal cut out..
** Question: When/If you make smoked overlays for the headlights, won't that dim down the brightness significantly??
