Autometer Single Steering Column Pod
Old Jul 29, 2004 | 09:59 AM
SuperHatch's Avatar
Originally Posted by trinydex
hey, do you think if you drilled in teh stock mounting points you could get the lancershop / gauge works pod to REPLACE the stock steering column piece, or is it just not possible.
I really don't think it's possible. The inside of the stock cover has studs formed into it that the screws go into from the bottom. If you could somehow remove them from the stock piece and fasten them to the autometer pod (jb weld? ) then maybe. But it still doesn't solve the clearance issue, the replacement cover will still be as big as it was when it was on top of the stock piece.
- Steve
Old Jul 23, 2005 | 10:40 PM
hc434's Avatar
Anyone find any issues with rubbing not because of the push pins, but just the fact that the pod will incrase the thickness of the steering column, and so rubs no matter what....Any suggestions how this could be fixe? I don't really know if I want sand it down since I don't have the proper tools for such a job...
Old Jul 23, 2005 | 10:51 PM
phenominalpinoy's Avatar
i have the one in the first pic and i can see everything fine...its a nice fit
Old Jul 24, 2005 | 01:13 PM
Jakeg97's Avatar
Originally Posted by caymandiver75
I would also assume with the first picture the guage would look more clean and sit lower. I'm just trying to verify this.
you are correct
Old Jul 24, 2005 | 01:18 PM
budlong's Avatar
it covers up the part of your speedo that most people never see anyways. where i sit, it only blocks from about 130 up.. shouldnt be an issue.
BUDLoNG
Old Jul 26, 2005 | 02:46 AM
krayzeviet's Avatar
i like the second one..... i like to keep my greddy turbo timer on top of the steering column... and i think the second option would suit my needs best
Old Jul 26, 2005 | 03:08 AM
awdjunkies's Avatar
Originally Posted by burningmoney97
you are correct
I would love this look as well with the defi Boost gauge/Single gauge Pod, but I also have to think about the Blitz TT that sits ontop of the steering column
Is there any way to correct this problem without removing the TT??
Old Jul 26, 2005 | 03:12 AM
awdjunkies's Avatar
Originally Posted by SuperHatch
Here are the pics of the Autometer Single Steering Column Pod installed. The installation was pretty simple. It requires drilling your factory steering column cover, since the pod attaches to the steering column in the same way as the old school A-Pillar pods, using the push pin type holders. I should have done more research, I was under the impression the Autometer pod was a replacement for the upper plastic... live and learn. I'm not going to get into the wiring and boost source connection of the gauge.
Am I happy with it? Yes, the gauge placement is much better than the all too familiar A-Pillar placement. The only thing the gauge blocks is the speedo >140MPH. I don't venture there too often (read: at all) so I don't miss it. The Tach is completely unobstructed. I am 6'0" tall, so this is from my point of view. I would imagine the shorter you are, the more of the speedo gets blocked.
The only thing I am unhappy about is the clearance between the pod and the steering wheel. The last pic shows this, it is a very tight fit. When I first took the car out for a ride, I could hear the plastic pieces rubbing (very annoying) but after one night of driving, the rubbing is gone. I would also blame the noise on my placement of the push pins, as they are the highest point on the front of the pod. These pins can be installed anywhere, I put the two front ones on the front of the pod between the column and the steering wheel in an effort to hide them. Turns out it came around to bite me in the a$$. No biggy, it's quiet now, but at first I was upset with my mistake.
Well, I'll shuttup now and let the pictures speak for themselves, if you have any questions just ask or PM me.
- Steve
Wait!!! Actually these pics that superhatch posted are what I was needing ... I see/guess I have to move my TT to the position he has it ..
Old Jul 26, 2005 | 01:44 PM
Jakeg97's Avatar
you still can
how 2 - https://www.evolutionm.net/forums/sh...d.php?t=140212
pics take some time 2 load
