Orbis 10 inch sub w/ Real CF enclosure only 13lbs!!!
Old Sep 5, 2004 | 10:43 PM
v8killer's Avatar
Anyone ever heard of this? Or Orbis Audio? I have seen and add in the Turbo and Hi-tech Performance magazine (the one with the white Evo on the cover), and today I picked up a copy of Car Audio and Electronics mag, and they had a test review on this sub and enclosure.
The sub/enclosure was rated very well. The sub they said is fairly high tech and has a peak power rating of 400 watts. The enclosure itself is very small and the best part about it is that the enclosure is made from a single piece of real CF! They are made by hand. The owner of the company, managed somehow to wrap a sigle piece of CF sheet around the globe, without overlapping or cutting. He found a way to stretch and shrink the CF.
The sub and enlosure altogether weigh only 13lbs! That's awesome, considering most decent subs out nowadays weigh over 20lbs alone, not to mention a ver heavy MDF enclosure. These things go for $599.95 shipped. I wonder if you guys would be ineterested in a Group Buy? I am thinking of getting two of these.
Here is there website, http://orbisaudio.com/
but if interested you should really pick up the Car Audio and Electronics mag, (Wayne Brady's Escalade on cover)
Attached Thumbnails Orbis 10 inch sub w/ Real CF enclosure only 13lbs!!!-orb-sub-insatalled2.jpg
Old Sep 5, 2004 | 11:08 PM
Forbiden's Avatar
Eh, I could be wrong but I bet it sounds like ***. (Bazooka Tubes come to mind).
Old Sep 5, 2004 | 11:11 PM
Sentinal's Avatar
600 bucks for something you know isn't going to keep up with a real sub enclosure... not going be in my Evo...
Old Sep 5, 2004 | 11:18 PM
v8killer's Avatar
Whose to say it won't keep up? A single one did 122.4 max DB SPL in the test. I imagine two of them could pull off 126-7 DB. That's plenty loud for me, and the weight savings it tough to beat.
Not all Bazookas suck, I heard a pair of 10 inch top of the line models ina extrab cab truck and they souned pretty freakin good! Thumped pretty hard. And I do know the difference, back in the day... I ran a 1500 watt 140+ DB Soundstream equiped maxima.
I bet we could get two for $1000.00
Old Sep 5, 2004 | 11:23 PM
Forbiden's Avatar
The sub is only as good as the install. I said it probably sounds like *** because of the rounded enclosure.
Any sub in a Hatch-back or open-cab vehicle will sound loud. (not necessarily good though) Put those same "top of the line models" in a trunk and I bet they don't sound nearly as loud. And your opinion will change.
Anyways, I just think $600 bucks for that is insane. Atleast until I see and hear it in person.
Edit: Using weight as a deciding factor for subs, to me anyways, is a pointless thought because when go Auto-X or Drag I'm going to take the sub out of my car whether it weighs 13lbs or 130lbs.
Old Sep 5, 2004 | 11:25 PM
Sentinal's Avatar
You seriously think that is going to keep up with these baby's?
Attached Thumbnails Orbis 10 inch sub w/ Real CF enclosure only 13lbs!!!-smjl-subs.jpg
Old Sep 5, 2004 | 11:36 PM
v8killer's Avatar
No, I never said that it would... But I bet the extra 125lbs in your trunk says my car can keep up though!
Forbidden, true a sub enclosure could be taken out for track days, but not in Mr JL Audio's case, he does have a nice custom install, but obviously it is there to stay. Furthermore I like having the daily dose of speed, and if they sound as good as this very reputable Car Audio mag says they do, then they defiantely are on my list.
$600.00 is alot of money, but you know there are single subs out there for twice that much. All I am saying is that I like the idea and if it does indeed perform, you get both the look (real CF), the compact size, and the 13lb total weight!!! Very Nice! IMHO
Old Sep 5, 2004 | 11:42 PM
Forbiden's Avatar
True. I totally agree, like I said I can't really say anything until I see/hear it in person. But based on what I know now it's not worth it
Sentinals install looks a bit like mine, except I have a single sub in a similar sized box. I just remove mine when needed. Even when my car was stock I didn't notice much of a decrease in performance, if any. I do however notice a huge difference in handling / braking.
Old Sep 5, 2004 | 11:46 PM
Sentinal's Avatar
its actually only about half that much less noticeable than even 1 person in the front seat
I used high effeciency W3's instead of going with the huge magnet ones so they don't weigh as much as most people think and with 3 of them they put out plenty.
Old Sep 6, 2004 | 09:04 AM
imajinmyfx's Avatar
it wouldnt really make a big difference if u have a sub box or not. so ur telling me that a 130 lbs. driver would beat a 250 lbs. driver? ...
sentinal, nice setup... how do the w3's compare to the w7's? ..
Old Sep 6, 2004 | 10:16 AM
EVOTEXAS's Avatar
With ALL other variables equal, yes he would. By a little over a car length in the 1/4 mile.
Old Sep 6, 2004 | 11:05 AM
evo81's Avatar
thats some good stuff going on in your trunk .JL is sweet
Old Sep 6, 2004 | 02:16 PM
v8killer's Avatar
Yes, 125lbs will make a diff in the 1/4, not sure about a full car length, but maybe a half. The further you accelerate the more the difference will be noticeable.
Don;t get me wring I love JL's and I like the setup, I once had 3 10w6's in a custome enclosure in the back of a camaro! I was just trying to maybe try something different.
Back to the topic though, has anyone heard anything about these Orbis subs?
Old Sep 6, 2004 | 02:26 PM
evo81's Avatar
no never heard of them
Old Sep 6, 2004 | 02:47 PM
vegasboy301's Avatar
what a nub
