Moore Automotives Evo Builds
Since we have been getting our name out we decided to step it up.
I recently blew my headgasket and the ARP studs stretched being old so head obviously lifted. I took the chance and im fully building the motor and trans. I blew 6 gear out a week prior so now a 5 speeds going in. Im doing a 2.0 long rod motor bored .20 over. ENGINE Wisco 2.3 stroker pistons .20 over MAP 156mm Ultimate Duty I beams Master gasket kit OEM New oil pump Balance Shaft elimination Kit w/bearings and Seal Cap Kiggley HLA MAP Setrab Oil Cooler kit w/ss lines OEM Crank Supertech valves black nitrate coateing Supertech valve guides supertech valve seals ACL Race bearing MAP REV 2 OMNI 4 BAR MAP ARP 625+ Head Studs "ARP-207-4302" Sparktech ignition non-CDI Battery relocated to Trunk Optima Redtop w/ SS battery Tray TIAL QR BOV w/ETS Recirc Tube Mil Spec 65mm TB "Thanks Matt@spec-ops" Transmission/Suspension Torque Solutions trans,passenger & Rear Motor mount kit AP Front lower Motor mount Exedy Twin Disc HD MAP Clutch Fork Stop STM 1 piece SS Clutch line 5 Speed Swap "Built by buschur Racing w/ Evo VIII 4th" B&M Short Shifter w/Torque Solutions Shifter base bushings Redline Custom Shifter Boot for my 5 speed swap. Fuel & Cooling FIC 1450cc Injectors Buschur Racing Double Pumper STM Fuel Lab FPR kit AEM Meth Kit w/ Direct Port Meth w/4x CM5 nozzels"sleeper Job" ETS 3.5 FMIC Kit"modified for T3 Turbo Setup Suspension STD R3 Suspension Whiteline Roll Center Adjustment kit Turbo setup TURBO TRIX T3 tubular mani Turbosmart HyperGate 45mm Wastegate w/26psi in springs Bullseyepower CompR 62 S362 .70 A/R w/.82 3" V-Band Head will have a valve job and motor will get the works and be o-ringed. Ill keep this thread updated with pics and tuning progress. |
Bump added more parts and my setup.
Good luck on the build..should be a nice beast after the build is finished.
Nice build cant wait to see some pics!
Originally Posted by FLOW1
(Post 9771246)
Originally Posted by JTEVO2932
(Post 9771271)
Sounds like a pretty stout build I can't wait to see the results.
Originally Posted by cursedsm
(Post 9771291)
Originally Posted by Josh@MooreAutomotive
(Post 9771297)
Thanks. Alot of ny upgrades are due to Tom and his advice. You need to get that bottom end reinforced soon lol.
(Post 9771321)
Well I need to stay working longer then 4 days a month to build a motor hahaha. Skilled trades in Michigan are really really really slow right now. Holding on by the skin of my teeth litterly. But I'm sure as you know tax time is comming so my tax dollars will prob go twards property taxes instead of a new motor {thumbdwn}
You guys should open a shop here in Michigan being we need a good shop. The local ones out here do terrible jobs and you overcharged for shady tree mechanic quality. That way you can hire me and I don't have to be poor hahaha. And yes I have said this to all the shop guys I know hahahaha. Plenty of Ford and Chevy and Mopar but nothing good and quality for imports.
Interesting build! To be honest I've never heard of you guys! But it looks like it will be a solid build and a very interesting choice of turbo! Can't wait to see this play out
Originally Posted by evoforstevo
(Post 9774413)
Added more parts and info.
Ok today got a nice package in 4 gallons of Boost juice and my AEM Meth Injection Kit along with the Failsafe Monitoring system and gauge. I might also be swapping out the turbo don't know yet though.
