hubcentric rings??
Old Oct 15, 2004 | 12:42 AM
evotoo's Avatar
hubcentric rings??
I just got my gramlights in and it only came with 2 hub rings. Do i need 4 or only 2. If 2 only, does it go on the front or the back???
Old Oct 15, 2004 | 04:01 AM
4ce fed's Avatar
You need a set of four.
Old Oct 15, 2004 | 04:31 AM
Lightsped's Avatar
What is the purpose of the hubcentric rings? What happens if they are not installed on the wheels?
Old Oct 19, 2004 | 12:39 AM
nine4surfah's Avatar
bump....i want to know too?
Old Oct 19, 2004 | 04:21 AM
4ce fed's Avatar
First of all, it helps line up the lug holes, so the lugs can go on straight without you having to support the weight of the wheel, and line things up while you try and screw in the lugs.
Second, it helps support the weight of the car on the wheels. I'm not a wheel expert, but this is what I've been told, and it makes some sense. The stock wheels fit perfectly on the hub. It only makes sense that when the car is on the ground, the hub will be taking some of the force of gravity (3K+ lbs), as well as the lugs. No hubcentric rings, and the lugs have to take the full responsibility.
Old Oct 19, 2004 | 04:24 AM
ahh....ty!!
Old Oct 19, 2004 | 08:00 AM
EVOla_VIRUS's Avatar
What would be the dimension of hub centric rings for the stock Enkie's?
NSXLVR
Outlander Sport
Mar 14, 2017 09:00 AM
Igaly1021
Aug 15, 2016 07:56 PM
Stevo9267
Feb 23, 2016 09:22 AM
kylefowlie
Dec 21, 2015 11:54 AM
Piro Fyre
May 24, 2015 05:46 PM
