2nd piston ring bigger?
Old May 24, 2015 | 03:11 PM
Piro Fyre's Avatar
So I have Wiseco HD pistons in 85.5mm so I got the block bored .020" over. Did the math that came with the Wiseco rings and it's .017" top and .019" bottom. I grinded the top rings down to .017"-.018" just fine but ran into something weird on the 2nd. Without grinding anything off the 2nd rings, they all measured .021"-.022" on all cylinders. Should I contact Wiseco and tell them to get me new rings or just use these as-is since it's just .003" bigger than what I calculated.
Old May 24, 2015 | 05:46 PM
LetsGetThisDone's Avatar
It's fine. .018 top and .022 bottom is a good gap setup. If you're going big power (big turbo pushing 35-40+psi nearing 4 digit power numbers), I would open them up another .002'
Grimgrak
Jan 30, 2013 09:47 PM
ezzey
Dec 6, 2012 09:58 PM
rnbguy
Mar 31, 2011 08:12 AM
boostin'
Jun 21, 2006 01:28 PM
scoobymike
European Forum
17
May 13, 2002 05:28 PM
