Help my EVO is not steering straight!
Old Oct 23, 2004 | 11:11 AM
Space Monkey's Avatar
Alignment
Old Oct 23, 2004 | 02:57 PM
Alchemist's Avatar
space monkey- that's his problem he HAD an alignment and it's just as bad now, but on the other side!
EVOTEXAS- thanks for the backup on the caster (castor- whatever ) issue
bbbwrx- a LOT and I mean almost every shop I went to for alignments told me flat out- it is IMPOSSIBLE to get your steering wheel to go back to verticle. These shops said it would always have a noticable tilt to it. And that's just BS.
Here are just a few of the DIY alignment sites I studied before attempting (successfully) my own aligns. Some are obvioulsy more useful than others:
http://www.carcraft.com/howto/48938/
http://www.bodydynamicsracing.com/camber.htm
http://locost7.info/mirror/tools.php
http://www.negative-camber.org/jam149/alignment.html
http://www.vtr.org/maintain/diy-alignment.html
http://www.wincom.net/trog/alignment_rack.html
http://www.team3s.com/FAQcastcamb.htm
http://www.grubinski.com/grubinski/p...ment/index.php
Old Oct 23, 2004 | 03:39 PM
bbbwrx's Avatar
Quoted from:
http://autorepair.about.com/cs/gener.../aa012201a.htm
Caster:
Caster is the tilting of the uppermost point of the steering axis either forward or backward (when viewed from the side of the vehicle). A backward tilt is positive (+) and a forward tilt is negative (-). Caster influences directional control of the steering but does not affect the tire wear and is not adjustable on this vehicle. Caster is affected by the vehicle height, therefore it is important to keep the body at its designed height. Overloading the vehicle or a weak or sagging rear spring will affect caster.
When the rear of the vehicle is lower than its designated trim height, the front suspension moves to a more positive caster. If the rear of the vehicle is higher than its designated trim height, the front suspension moves to a less positive caster. With too little positive caster, steering may be touchy at high speed and wheel returnability may be diminished when coming out of a turn. If one wheel has more positive caster than the other, that wheel will pull toward the center of the vehicle. This condition will cause the vehicle to pull or lead to the side with the least amount of positive caster.
Ok i should have made myself a little clearer. It can affect pulling. But .3 degress? Most specs are given a +-.4-.5 ley way at least. Even more with castor since there is not a provision to adjust it installed by the factory. This .3 you would not feel that or even notice that while driving. I don't know about you guys but I will not leave my car with someone unless I trust them. I would take it back tell them it pulls and to fix it or give you your money back. Also have you checked the installation of your springs?
Yes all the shops that told you that are not a shop i would trust. They probably just said that so they wouldn't have to work on you car again.
And if all else fails ask them to hit the help button on the screen of there alignment machine.
Ben
Old Oct 23, 2004 | 05:14 PM
Alchemist's Avatar
HK Evo- you could try just flpping the eccentric bolt on one side and see if that helps. Take off the tire, loosen the top of the two large bolts on your strut and turn the entire bolt 180 degrees (no, do'nt take it out and flip it so it points the other direction, turn it with the wrench ). Retighten and replace tire. See if that doesn't help.
BBB- Sorry, I missed his report pic. My bad. and yeah, the number that worries me is the extreme camber difference.
Old Oct 23, 2004 | 05:47 PM
Hong Kong Evo's Avatar
Originally Posted by EVOTEXAS
Camber and toe is completely adjustable for a street car in the front and rear. Your alignment does not look good.
You should have them acheive something like:
Front:
Camber: -1.4 L/R
Toe: 0 mm
Rear:
Camber: -.9 or -1.0 L/R
Toe: .01 mm
There should be no left/right variation. Also, caster, which is not adjustable, can cause your car to pull. Some places can compensate with a mild tweak to camber.
Either way, your specs do not look good.
Yea I'll try to get my camber numbers right .... thinking that I might need to get camber plates for this tho .... anyone know if theres an alternative way to adjust the camber ? cause I believe the only camber plates i've seen are from cusco??
Old Oct 23, 2004 | 05:48 PM
Thanks for the info man ... I'm sure if ill find something in those links ....
Old Oct 23, 2004 | 07:49 PM
marksae's Avatar
The problem w/ flipping that eccentric bolt is that in addition to changing camber, it will also change toe. You can't adjust one w/o changing the other.
Old Oct 23, 2004 | 08:10 PM
jbrennen's Avatar
Does the car pull to the side if you take your hands totally off the steering wheel? If not -- if the car (on flat pavement) tracks straight ahead with hands off the wheel -- then your complaint is basically that when the tires are centered, the steering wheel is not. This is not a faulty alignment in the sense of causing handling problems, but it is a faulty alignment in a purely cosmetic sense.
This happens if the alignment shop measures and sets front toe while the steering wheel is not perfectly centered. Because you had such a big imbalance between left and right toe in the front, it leads me to think that happened here. They measured the initial alignment with the steering wheel slightly off center, and then they "fixed" the front wheels to point straight ahead with the steering wheel in that slightly off center position.
To some people, a few degrees off center doesn't matter -- to others, it's a constant annoyance. You should be able to get it fixed by the alignment shop -- but I seriously doubt that you will see any problems (other than the steering wheel being slightly cocked to the side) if you leave it as is.
Old Oct 23, 2004 | 09:37 PM
Another question I have is for people who fixed their alignment issue the second time ... did you guys adjusted the camber? if so how did you guys do it?
Old Oct 24, 2004 | 03:40 AM
LancerOZ's Avatar
Originally Posted by Hong Kong Evo
I thought about this too ... it seems to make sense ... but I only drove on these new toyos for about 200 - 300 miles ... and I think the possible amount of tire wear I could've done to it wouldn't be enough to pull the car to the left like how it is right now .... i thought about swapping around the wheels too ...
You'd be suprised. I would be willing to bet it's those tires. 200-300 miles is plenty of time on those aggressive compound evo tires to wear an alternative pattern into your tread on one side.
- Jason
Old Oct 24, 2004 | 08:27 AM
EVOTEXAS's Avatar
- Jason
Did you not see his alignment specs? Can you not tell they are way out of spec?
Old Oct 24, 2004 | 11:54 PM
3K's Avatar
3K
Listen to jbrennen, Hong Kong Evo. What he's saying is exactly right.
Old Oct 25, 2004 | 10:26 AM
Thumbs up
Yea that was the first thing I thought of too after they aligned it. I feel like the car was just aligned with the steering wheel off centered. I already reminded the guy working on the car a bunch of times before they started working on the EVO ... but anyway ... Ill visit good yr again and give it a shot with adjusting the cambers as well as paying attn to this particular issue.
Thanks for all the input guys .
KGHtheII
11
May 29, 2012 07:37 AM
Torntech
Lancer Troubleshooting
Jun 30, 2011 08:48 PM
Poloiceberg
Jan 23, 2011 07:01 PM
x838nwy
14
Jul 9, 2006 01:23 AM
dewman1999
10
May 1, 2005 02:21 PM
