How is the camber with the H-Techs?
Old Nov 2, 2004 | 12:39 PM
EVOSTEVO's Avatar
i am thinking of getting a set of Htechs for the evo and want to know if the camber will need adjusting for a 1.4f and .3b drop. also if anyone has feed back on them it would be apperciated.
-Steve
Old Nov 2, 2004 | 12:53 PM
EVOSTEVO's Avatar
bu bu bu bump
Old Nov 2, 2004 | 09:08 PM
EVOSTEVO's Avatar
bmp
Old Nov 2, 2004 | 09:29 PM
sophis's Avatar
Anytime you make adjustments to the suspension, the suspension geometry will change. Thus, if you lower your car, your camber will change amongst other things. Asking if you need to adjust the camber is subjective. Are you looking to go back to stock alignment setting or do you want more camber?
Old Nov 8, 2004 | 06:10 PM
EVOSTEVO's Avatar
i wanted to know is the camber changed when you install the htechs. i was going to have them put on and then get a wheel alignment. but will the camber be changed when i put them on?
-Steve
Old Nov 8, 2004 | 06:43 PM
EVOTEXAS's Avatar
He just said yes. How many times do you need to hear it?
Old Nov 8, 2004 | 06:48 PM
eve-slow's Avatar
I have those springs and I like them. YES, camber, as well as other specs will be out. Just get an allignment after. You don't have to right away because camber is not that bad and because usually, springs need a little time to settle.
Old Nov 9, 2004 | 06:06 PM
EVOSTEVO's Avatar
apparently i need to hear it more
i would also like to get a little feedback on the springs. i am also now considering hotchkins springs with the antiroll kit.
-Steve
Old Nov 9, 2004 | 06:20 PM
EVOTEXAS's Avatar
-Steve
You mean the rear sway?
I have the Hotchkis Springs and rear sway. I couldn't be happier this side of Ohlins.
Old Nov 9, 2004 | 06:28 PM
EVOSTEVO's Avatar
how much did you pay and where did you get them? i heard someone on the board got the swaybar and springs for 300 bucks.
does the sway up give the car a more rwd feeling or does it let you go into turns flatter?
-Steve
Old Nov 10, 2004 | 11:50 AM
EVOSTEVO's Avatar
bump on the hotchkins
keithislegit
Nov 23, 2011 02:57 PM
Sales@IveyTune
Evo 'For Sale' Suspension / Brakes / Handling
Jun 15, 2007 08:52 AM
umiami80
91
Apr 30, 2005 03:15 PM
spyderx
Oct 20, 2004 10:56 AM
Lightsped
Feb 24, 2004 10:08 PM
