Question for those with Tein Basic
Old Feb 15, 2004 | 11:55 AM
Lightsped's Avatar
Question Question for those with Tein Basic
So I am thinking about getting a set of Tein Basic for my stock Evo8.
The Tein Basic pics I have seen show the rear wheels with a moderate amount of negative camber. From what I have seen, having negative camber to the rear wheels will produce understeer if the front wheels have no camber in them.
Anyways, my question is, do the Tein Basics understeer more than stock? Also, what springs are used on the Basics? S-Tech or H-Tech springs?
Also, I am considering 17x9 wheels with 35mm offset. Will this produce problems with a Tein Basic setup?
Anything else I should know before I decide on Tein Basics?
Thanks in advance.
Old Feb 15, 2004 | 12:12 PM
AltezzaRoku's Avatar
when I had the TEIN Basics the only camber problems I had were in the front. And my car was lowered with about 1 finger gap on each tire. How much do you plan to lower your car?
I couldn't really notice any difference in understeer from stock with the Basics.....
until I got a set of RRE JIC's. After driving my current setup now, the understeer produced by the stock setup / TEIN Basics is much more apparent.
Old Feb 15, 2004 | 02:49 PM
Lightsped's Avatar
I am not planning to slam the car. Just a slightly lower ride height. Any issues predicted with 17x9 wheels at 35mm offset?
Old Feb 24, 2004 | 01:05 PM
C-Murdock's Avatar
is lowering the ride height limited with the Basics, compared to say the SS's or Flex's ?
Old Feb 24, 2004 | 10:08 PM
nope. you can drop your car to the ground.
SVTong
Jan 19, 2012 10:20 PM
lopex
16
Aug 25, 2009 11:01 PM
EVIL_EVO_VIII
Jun 24, 2006 08:47 PM
EVILbtownEVO
19
Oct 27, 2004 07:14 AM
Lightsped
Jul 19, 2004 07:43 AM
