Tein s-tech springs after install?
I installed Tein-s tech and i must say the car looks sick now!! But since you all know when you install springs the tires arent completely straight and either cave in or out. Who here has had springs on for more than 6 months with the stock camber? Have you had any problems? I just got new tires too and i dont want to have to change my tires again in 3-6 months
. Is it possible to adjust the stock cambers? What can i do? Dont have money for coil overs so its out of the question.Thanks
yes- just get a 4 wheel alignment immediately.
If you are into performance driving - you can get a performance shop to set a slight negative camber and toe out - then go do some autocrossing!
yup i installed them myself and i got it aligned after and perfect, no camber kit needed. if the alignment shop says u need a camber kit due to the springs tell them to stop lying cuz u dont need them for the S Techs.
ive read you loose handling with the teins and that the stock suspension was designed really well for the car. Maybe a upgraded set of swaybars would be the best ive also read hotchkis springs are pretty good there 5 ft pounds less up front and 5 more in the rear suppose to help balance out the car.
I autocrossed for the first time yesterday, I'd love to do coil overs, but 1500 for a good set up, and then the car doesn't even go faster, it's just too hard for me to do. Maybe I'll stick with the stock suspension, but do rear sway bars and tower bars. I bet that would help =p
Ive had mine for more than 6 months and I did get an ALIGNMENT or At least do it yourself. it was off exactly 1.3 degrees in the back and around 1 in the front. dont really remember.
have you guys noticed any wearing out of the tires either inside or outisde. Someone told me that even after an allignment they will still wear out fast b/c theres no aftermarket camber. Thanks
