Front wheel knocking noise
Old Dec 5, 2004 | 06:09 AM
Roadblock's Avatar
Question Front wheel knocking noise
Hi.
I have a 2001 Evo 7 with just under 35000km on the clock.
For the last couple of months, it has been making a worrying noise and the local Mitsu dealer cannot figure out.
The problem is that as I start off in 1st gear with the front wheels turned to either side, there is a knocking noise coming from the front outside turning wheel. For example, if I am turning left, the noise comes from the front right wheel and vice versa.
Also, if I take a corner and put a high load on the wheel, there is a rumbling noise.
With the wheels centered, there is no noise, so I don’t think that the wheel bearings are at fault.
The first time I brought it back to Mitsu. they said that the brake pads were loose and they had put more grease between all 4 of the pads and the shims. I was a little suspicious, as I had recently put grease on them all.
The second time I brought it back, the noise had gotten worse, they changed the small suspension links on both sides, but it made no difference.
I thought that the drive shafts were probably busted, so the third time that I brought it back, I told them what I thought and they changed both drive shafts. Driving out of the garage, the noise was still there, as bad as ever.
I brought it back again and now they are going to take it back to the factory.
I have checked the wheel bearings for play.
They brake pad retaining pins and spring are all tight.
Hopefully the factory will fix it but I want to know if any of you have any idea what the problem might be?
Any ideas would be really appreciated.
Old Dec 5, 2004 | 07:18 AM
x7eVoLuTiOn7x's Avatar
I got evo 7 too....same problem. This should solve your problem.
https://www.evolutionm.net/forums/sh...01#post1440101
Old Dec 5, 2004 | 07:39 AM
KazzEvo8's Avatar
Wow, that sounds like a bad CV joint on a FWD... but I have no idea on our Evos, no mechanic here, sorry.
Old Dec 5, 2004 | 12:34 PM
96_LXR's Avatar
Just an FYI, on several other front drive cars I've owned, they have all made a sound that you would swear are bad wheel bearings but every time it has been caused by the start of a funky treadwear pattern on the tires.
I had front wheel bearings replaced under warranty at 90k (on a Civic) and it still made the same noises. Went home and put on the stock wheels and tires and the noise was gone.
Sorry this is a little OT but just thaought it might be of some help.
Good luck
kozmic27
Evo X How Tos / Installations
32
Oct 28, 2019 04:39 PM
Liquid0401
For Sale - Cars For Sale
14
Apr 15, 2016 12:27 PM
GregGSC
Dec 8, 2009 09:18 PM
Richard EVO
31
Feb 6, 2009 06:48 PM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
149
Jan 20, 2009 09:01 AM
