Coilovers + Cold Weather = Squeeks ?
Old Dec 15, 2004 | 07:33 PM
en1gma19's Avatar
I recently put a set of coilovers on my car. I have been driving with them for about 250 miles and have no complaints except for this. One, yes just one, coilover (passenger rear) squeeks when going over bumps. It seems to be more prone to do this in cold weather.
I took the wheel back off to make sure everything was tight enough, and it was. So, then I put a jack under the control arm and lowered the car with the wheel off. I had my sister bounce up and down to reproduce the noise, which worked.
It sounds like the noise was coming directly from the spring. Does this make any sense? Could the cold weather make the spring creek, or squeek? Is it preloaded too much? Not enough? Any insight from people with more experience would be great.
Thanks
Old Dec 16, 2004 | 03:19 PM
en1gma19's Avatar
bump
Old Dec 16, 2004 | 03:23 PM
EvolvedDragon's Avatar
interesting.....I have has the same phenomina with the stock suspension anyone have any ideas?....
Old Dec 16, 2004 | 03:27 PM
en1gma19's Avatar
i am beginning to think it is a blown strut. The side the noise is coming from bounces a lot more than the other side. I'm thinking that means blown strut.
Old Dec 16, 2004 | 03:29 PM
speedomodel's Avatar
Coil slap, perhaps? I believe Tein makes a rubber silencer sleeve that you can slide onto the spring coil.
Old Dec 16, 2004 | 03:30 PM
en1gma19's Avatar
what's coil slap? sorry, I'm new to suspension stuff.
Old Dec 16, 2004 | 03:51 PM
When the spring is compressed the angled coil before the end-coil can actually impact the end-coil, generating some noise. The rubber sleeve covers this last angled coil.
Old Feb 19, 2005 | 02:14 PM
swiftny2's Avatar
I have an 05' stock Evo. I have that same CREEKING sound from the passenger side rear.... first noticed it on a really cold night, but more frequesntly since. I'm thinking about taking it in for a look at the dealer. Any suggesions or thoughts, also i've noticed a thumping noise on that side particularly when going over bumps. I'm not sure what to do... SPEEDO i'd like to know if you've ever dealt with this noise/problem before. and ...ENIGMA.... fill me in on your situation too. thanks dudes.
jager89
Mar 3, 2013 10:12 PM
silentmunky
Lancer Troubleshooting
10
Nov 13, 2007 11:36 AM
whoang40
Oct 1, 2007 10:34 PM
outsider
Feb 8, 2005 09:18 AM
Wolfe
Feb 13, 2003 05:22 PM
