Here is how to fix your high speed brake vibrations...
Yep, mine had it too. Resurfacing the rotors worked for awhile. But I wasnt going to do it again. I would like my rotors to last awhile. So i jack up the car. All fours off the ground. Pull tires. Pull calipers and wire them out of the way. Just take out the two mounting bolts. Simple. Look inside the calipers, you will see the brake pad surface. Take a 60 grit rigid sanding disc and scuff all the glase off. Both sides. Now have your buddy start up the car and put it in first. Get the rotors spinning. You will need a Makita 4" grinder or equilevent. Makita makes a sanding disc that look like it has a bunch of little flaps of sand paper layed down on each other. This worked perfect. While the rotors are spinning, hold the sanding disc on the rotor (90' to the grooves on the rotor) and move EVENLY from left to right. Keep repeating until most all the shinny is gone. Check out the picture. This took off very little metal. Mainly roughed up the surface. Put it all back together and break em in like they were new. Ime sure it will happen again, but ill keep doing this little 2 hour fix until i find a better one.....RRR
I dont have ACD. Dont know how any stress could build up with the tires off the ground. Only issue to figure out was how to get each of the fronts to spin since its not LSD. Well, i mounted a tire on the opposide side i was working on. The weight caused the other side to spin. Then change sides take off the tire and mount the other side. Then that side will spin. Seems like the side with the lease resistance would spin.....
you know, it could have been just the fronts. Dont know. I really dont think its a warping issue though. My dial indicator only moved 3 thousandths. There is no way thats enough to vibrate the wheel out of my hand.
Originally Posted by Ty-Evo8
Just to give a relative idea of how small .003" is, a sheet of paper is typically .004" thick.
