Evo 7 bolt pattern
Old Jan 1, 2002 | 07:39 PM
Pete's Avatar
Evo 7 bolt pattern
Should I assume that my OZ F1 Cup wheels I have for my 2G Eclipse will match the bolt pattern for the Evo 7? The wheels are 5x114.3. It's be nice if I don't have to get new ones. The Kumhos on them are 245 wide, so I imagine that'd fit no problem.
Pete
Old Jan 2, 2002 | 10:17 AM
snelson's Avatar
I don't know the answer to the question because I don't recognise the size 5x114.3 It is the 114.3 that throws me, we probably call it something else in the UK.
However, the other problems you are likely to face is whether the offsets match and whether there is enough clearance inside the wheels for the brake calipers.
Old Feb 13, 2002 | 10:20 PM
COEVOVII's Avatar
eclipse bolt pattern Vs EVO vII
The bolt pattern he specified is 5(holes)x 114.3mm spacing i.e.center to center of the holes. I need to know this info also. As I would like to swap my OZ sapperlaggeras onto the lancer. From the pictures I've seen the offset on the EVO (maybe 35mm) looks smaller than that of the eclipse (46mm or 48).
If anyone could post the wheel specs for the VII or a link that would be great.
James
Old Mar 26, 2002 | 12:23 AM
Pete's Avatar
bump!
Still curious if anyone has found an answer to this.
Pete
Old Mar 26, 2002 | 01:45 PM
Michaelk's Avatar
Simon, simon.... THAT is the only right way of describing a bolt pattern. Pete, it is exactly the right bolt pattern for a 6, but I don't know about the 7 although I suspect it is the same. It's only the ET which is different between the 6 and 7 I believe.
Tims2006MR
Aug 26, 2011 01:21 PM
Kronik
Nov 18, 2008 05:22 PM
Greyman09
Jul 12, 2004 04:21 AM
zyounker
Mar 28, 2003 03:01 PM
