Steering vibration
Old Apr 1, 2005 | 07:50 PM
pmysko's Avatar
no input but same sh*t here
Old Apr 1, 2005 | 07:52 PM
massinine's Avatar
its the potholes
Old Apr 1, 2005 | 07:53 PM
massinine's Avatar
i swear to god i saw a car disappear in front of me, turns out it was a really big pothole
Old Apr 1, 2005 | 07:56 PM
04lancerEsGuy's Avatar
My 04 ES had that problem last week. Took it to the body shop, ran dyno and found out that there were 3 things that were wrong.
(1) Right wheel bearing was damaged so i replaced it.
(2) Suspensions were damaged because i was into an accident. (Replaced Suspensions)
(3) Allignment was messed up
total was $1300.00
Now it runs as sooth as before.
This was problem in my car, but i dunno if its same for you guys as well.
Good Luck !!!!
Old Apr 2, 2005 | 02:16 PM
VegasEVO's Avatar
vibration
Well, i had the exact same problem. The steering wheel would vibrate profusely above 70mph. I then put on a set of hotchkis springs a couple weeks ago. While i was under the car i tightened everything up including the control arms. Since then the car drives smooth as it was when i first got it. I would recomend just tightening everything and check for cracks/looseness in your suspension.
Old Apr 2, 2005 | 03:09 PM
FinsNCanes's Avatar
I only get it when I break going over 70..
I'm sure that isn't good either though
Old Apr 2, 2005 | 03:24 PM
Mivo's Avatar
figure it out yet?
Old Apr 3, 2005 | 04:17 PM
GBEvo's Avatar
Mine does it periodically when breaking on the highway too but the pads and rotors look good. Only 11K on them. I'm going to the Mitsu shop next Sat. and I'll have them look at everything to see if anything is bent/loose.
Old Apr 3, 2005 | 04:22 PM
watchout's Avatar
You have a warped or warped rotors.
Shane
Old Apr 4, 2005 | 06:41 AM
hotrod2448's Avatar
If you are on the factory pads still it could be pad transfer to the rotors. The factory pads are bad about that.
Old Apr 5, 2005 | 01:37 AM
RaceBiscuit's Avatar
okay a weird question - I have steering wheel vibration too, just driving at high speeds. Just had a new (used) wheel put on after hitting a median, and had all tires balanced/rotated at same time. If I have directional tires, and they rotated my wheels as if the tires were non-directional, could that cause the vibration?? (i.e., one or more of the tires are on backwards) eh? eh?? what do you guys think?
Old Apr 5, 2005 | 10:59 AM
bcmind's Avatar
I had the same problem and got the answer
http://www.socalevo.net/forums/viewtopic.php?t=8468
Old Apr 6, 2005 | 12:18 AM
^^ yeah, but when the vibration only occurs during high-speed driving, not braking, it's a different issue.
Old Apr 7, 2005 | 09:37 PM
spyderx's Avatar
same here!
Old Apr 9, 2005 | 01:02 PM
GBEvo's Avatar
Tires balanced and rotated and still have steering wheel vibration on the highway. Brought it back to Mitsu and had everything checked out and they said everything was tight. Steering wheel still shakes. No solutions yet. Anyone else have any luck?
