popping STRUT bolt - help!!!
Old Mar 30, 2005 | 05:51 PM
4-BNGR's Avatar
What I thought was the lowering springs (pop/crack) sound turns out to be the center bolt between the 3 bolts that thread the strut assembly to the strut tower brace. wheel lock to wheel lock the noise is apparent. the right wheel is not doing this. the spring is seated properly. wtf can I do about this? help!!!
Thanks in advance
Old Mar 30, 2005 | 07:50 PM
4-BNGR's Avatar
Solution(s):
1) 3/8" high pressure rubber hose over spring coils
2) replace stabilizer end link (mitsu part # MR316369)
3) replace strut (not likely the problem)
Clunking will be gone...
Old Mar 31, 2005 | 08:44 AM
Ev0 1's Avatar
Do you have a picture of all that?
Old Mar 31, 2005 | 09:10 AM
4-BNGR's Avatar
Wrap the rubber hose between #4 and #7
Old Mar 31, 2005 | 09:14 AM
Ev0 1's Avatar
Thanks, Do you have a picture of the rubber hose? Where can I get it from?
Old Mar 31, 2005 | 09:24 AM
4-BNGR's Avatar
Sorry, no pic. Go to a plumbing store (Home Depot/Lowes) or any Car Parts store. Get 2 3/8" diameter hoses - 4" long. Spray some WD on the spring (a little) and slide them over the spring. Reassemble the spring/strut. Lower the car. Say you prayers and turn the wheel... lock to lock.
And get that alignment. Should be $60 bucks for the alignment. More is a rip off...
Old Mar 31, 2005 | 09:33 AM
Ev0 1's Avatar
Sweet! So I just put it on like a glove? lol Thanks man
Ta
Old Mar 31, 2005 | 11:48 AM
mayhem's Avatar
Sure it just wasn't torqued down correctly. I've had to go back and retorque those nuts on other cars before AFTER they were mounted on the car was standing on it's own.
Old Mar 31, 2005 | 12:14 PM
M3rcer's Avatar
Yeah man, I had the same problem with my S techs. The installer torqued them down wrong and stripped out the male end. Get coilovers to take care of the problem
Old Apr 1, 2005 | 10:17 AM
mayhem's Avatar
Do what? Why get coilovers when you could just retorque the nut?
Old Apr 1, 2005 | 01:16 PM
M3rcer's Avatar
I was just kidding, jeez
Old Apr 2, 2005 | 10:18 AM
Ev0 1's Avatar
How much do you need to tq them down?
Jim3142
23
Jul 22, 2016 07:49 PM
alexc
Dec 9, 2015 01:08 AM
Boltz.
Jun 20, 2011 09:26 PM
mike127
28
May 7, 2007 10:23 AM
Wheelhaus
15
Apr 23, 2007 12:07 PM
