Tein vs HKS coilovers
I have the Hipermax II's and I have really enjoyed them to tell you the truth... the ride is just a bit more stiff than stock, but the damping is excellent in my opinion. It's hard for me to give you a comparison between the Hipermax II's and the Tein because I haven't driven a car with the Tein's. I would definitely recommend the HKS setup to you though because as always the quality and fitment is excellent and the performance is a great compromise between track and street.
I have the HKS hypermax damper IIs. The ride is about the same as stock on the street. The Teins are alittle more track oriented with a higher spring rate.
HKS Hypermax II:....392lbs(7.0k).....336lbs(6.0K)....Adjustable
Tein Flex:.................504lbs(9.0K).....448lbs(8.0K )....Adjustable
Stock(USDM):..........180lbs(3.2k)....225lbs(4.0k) ......STOCK
The HKS should work pretty good at the track but not as good as the Teins. If your going to be mainly on the street go with the HKSs
You can even go with the Tein SuperStreet if you are not tracking your car. The EDFC will be compatible. The softest setting on these coilovers is more comfortable than stock.
Originally Posted by NoTiGuY
but the upper mount of the Hipermax II will give way very soon, so i've heard.. making all those knocking sounds which irritates the h3ll out of ya... is that true?
alrite...i'd guess its the roads here in malaysia then.... so many of the hipermax II users have the same complain.... even when i had my hiper-d on my other car, i had no problem at all and the rest of them were complaining with regards to this matter... even friends from singapore..sigh..... why is this so....
2ndly, from your chart, how come the usdm has harder rates on the rear compared to the front?
https://www.evolutionm.net/forums/sh...ad.php?t=66296
Originally Posted by Z1 Performance
Zeal Function V6...and you'll never complain
Hands down the most versatile coilover out there
Adam you been in a car with HKS Pro coilovers on the streets, how the ride?
