tire wear
Old Apr 14, 2005 | 10:35 PM
MrMejia's Avatar
tire wear
okay ,
I think I may have a problem. My 03 EVO is running 32psi all around but I am getting some pretty wierd tire wear. my right rear tire seems to be wearing slightly faster than all the others. My 2 left tires seem to be wearing more on the inside, but my 2 right tires are wearing evenly. "shouldn't the 2 front tires of the EVO be wearing quicker than the rear???" I do have redline fluid by the way in the diff's and tranny. I guess if my right rear tire is wearing quicker im assuming that means i have oversteer. can anyone explain this?
Old Apr 15, 2005 | 05:27 AM
mayhem's Avatar
All I can say is get an alignment. I had mine done and the rear toe factory setting was fawked. One wheel was pointing and and the other was pointing out.
Old Apr 15, 2005 | 05:31 AM
kingkyle's Avatar
did you put springs on your car? If so.... your springs caused toe out and thats why your tires are wearing funny. go get a good alignment
Old Apr 15, 2005 | 06:36 AM
Neal@tirerack's Avatar
ditto
Old Apr 15, 2005 | 08:19 AM
evolved04's Avatar
stock alignment on almost everyones evo was/is screwed from the beginning. i think that has alot to do with people toasting advans even faster than they should be.
Old Apr 15, 2005 | 11:55 AM
MrMejia's Avatar
actually my allignment settings were already re-done. I have a stock suspension set up and everything is as it should be (within manual specs). could it be my driving style or PSI levels? I'm going to try 35psi in front and 32 in rear see if anything changes.
Old Apr 15, 2005 | 04:30 PM
tobz's Avatar
alignment
My camber was way off. Mit paid for new tires and alignment. Lowered it now and the left toe is way out?
