Tein or Cusco camber plates?
Originally Posted by Z1 Performance
I dont see what one has to do with the other frankly - the spring rate and camber plate operate independant of one another - one does not affect the other.
As for changing the spring length, you have to check with your coilover manufacturer on this one - if the coilovers are dual height adjustable, I don't see a problem. If not, you might end up altering the stroke of the shock itself.
As for handling the higher springs, I cannot fathom how they couldn't - example: there are certain Cusco applications that come with 10 kg/mm springs (559 lbs) as stock, and they work just fine
thanks!
Originally Posted by kekek
chrisw...aren't the GC plates supposed to have caster adjustment too? I thought Navid mentioned something about that in the SM Update thread...
--Navid
Spun Autosports
Evo 'For Sale' Suspension / Brakes / Handling
25
Jun 26, 2007 08:38 AM
Spun Autosports
32
Jun 4, 2007 10:31 AM
XIRMOVE
16
May 24, 2007 03:11 PM
Vivid Racing
Jun 27, 2003 12:19 PM
adjustment, bad, bearing, camber, cusco, evo, evom, installation, installed, lowerspings, mr2, plate, plates, range, tein
