Tein or Cusco camber plates?
thanks.
some specs will be great and some comparison if possible and real life experience, pros and cons.
all i know is that the tein ones are cheaper than cusco.
Originally Posted by 144mph
also might want to throw works into the mix too. I'm very interested in hearing some thoughts from those with the parts installed.
Dave
I have the cusco plates on ohlins road and track coilovers. They have been on the car for almost a year now. I hate the cusco plates.
Can't get much camber adjustment out of them. With the stock adjusters at max positive camber (for tire clearance) I can barely get -2.1 degrees with out hacking the plates to offer a lareger adjustment range. The spherical bearing bind causing creaking and twisting of the inserts (really bad for seals in the coilovers)
At this point I am problably going a set of Ground control camber plates. These are the plates I would have gone with in the first place if they had been available.
I would definately recommend that you pass on the cusco plates. If the tiens are anything like cusco, I would pass on those as well.
Originally Posted by kekek
chrisw...aren't the GC plates supposed to have caster adjustment too? I thought Navid mentioned something about that in the SM Update thread...
GC plates also incorporate a thrust bearing to prevent the binding issues that I complained about, something that no other camber plate (mentioned in this thread) has.
Originally Posted by plokivos
so i guess nobody has the Tein one...
I want something at least -3 degree up front...
ok, i guess I'll be guinea pig for the tein.
how much are the works?
The Tein plates can get you there...mine will hit -3.2 or so on my RA's. Unfortunately I have another problem which prohibits use of more the -2.25.
The Teins do not incorporate any type of thrust bearing to allow rotation of the spring in the seat. In fact you can hear the springs shifting on occasion.
lets keep in mind though that chris's issue in terms of adjustment stems in large amounts due to the fact that he is standing the tire to positive camber with the factory adjustment, then using the camber plate to dial in negative camber. Problem is, if you want to use a super wide tire up front, this is just one of things you need to do.
The GC's look interesting as well, though have not used them
However, I can fix this by switching to a 8" spring in front instead of the 10" spring I have now. This will give me the clearance I need to run the factory adjustment at max negative camber.
But at this point I feel like I have reached the safe limit of the cusco plates. I don't know if the cusco units can handle the higher spring rates that I want to use. From the dealers that I have talked to (here in the SF bay area) they don't recommend going much higher than what I already run.
Maybe you can answer this, can I safely run more than a 500lbs spring with the cusco plates?
I feel like I am stuck with my suspension setup the way it is until I get better camber plates.
I dont see what one has to do with the other frankly - the spring rate and camber plate operate independant of one another - one does not affect the other.
As for changing the spring length, you have to check with your coilover manufacturer on this one - if the coilovers are dual height adjustable, I don't see a problem. If not, you might end up altering the stroke of the shock itself.
As for handling the higher springs, I cannot fathom how they couldn't - example: there are certain Cusco applications that come with 10 kg/mm springs (559 lbs) as stock, and they work just fine
