What tire size for 18x9 with 34mm offset?
Old May 6, 2005 | 04:43 PM
1BADASSEVO8's Avatar
I have some 18x9 Volk SF Challenge with a 34mm offest on Tein Flex coilovers. What size tire are you guys running with these? I am thinkinh 245x40x18 or 255x35x18.
Old May 28, 2005 | 07:42 AM
Willie Dynamite's Avatar
bump
Old May 28, 2005 | 10:11 AM
4G63Rules's Avatar
what are your purposes? are you going to be doing alot of highway driving? drag racing? autox?
Old May 28, 2005 | 04:25 PM
For me it's a daily driver.
Old May 28, 2005 | 06:46 PM
evo81's Avatar
Old May 28, 2005 | 11:18 PM
'ringmeister's Avatar
i run same size & offset (actually 35mm, bit close) with 255/35-18 pilot sport2. no clearance issues before & after lowering it. bear in mind that not all tire of same size are created =. check tire racks full specs and they will give you the ACTUAL with of the tread and section. for example the pilot 255 is 9.7", a r-compound 255 tire i checked (might have been dunlap supersport) was 11"!
Old May 29, 2005 | 11:40 AM
4G63Rules's Avatar
255-35 should be plenty for your purposes.
Old May 29, 2005 | 01:02 PM
lil'evil_evo's Avatar
255/35 or even 265/35
Old May 29, 2005 | 01:07 PM
littlegif1's Avatar
I run a 255/35 on an 18/8.5 rim w/ the tein flex. There doesn't seem to be any clearance issues that I can see but you may want to be careful on how far you lower your car.
Old May 30, 2005 | 12:43 AM
Corey's Avatar
Post some pics of this please....
Old Jun 7, 2005 | 07:49 PM
How do you like those tires?
Old Jun 9, 2005 | 08:18 PM
go_evo_go's Avatar
245/40/18
Old Jul 12, 2005 | 04:03 AM
krayzeviet's Avatar
i have 18x9 volk sf-challenges and i'm lowered on tein h-techs.... i'm running a 245/40/18
Old Jul 12, 2005 | 06:22 AM
dude's Avatar
255/38/18 is probably your best bet without any rubbing issues. 265/35/18 is closer to stock rolling diameter, but you might run into the inner fender lip in the rear and possibly the spring perch in the front.
