cusco bars...
cusco bars...
hey guys...im wondering what kind of bar...(i prefer cusco) will i need to make the car not drift as much? like doesn't slip out as easy....and why are there different mm sizes for them...does that make a difference what size it is? thanks guys...
You might want to review this description:
http://www.rallycars.com/Cars/4wd_turbo_cars1.html
Then, adjust the characteristic with this:
Adjustment More Understeer More Oversteer
1. Front sway bar Thicker/stiffer Thinner/softer
2. Rear sway bar Thinner/softer Thicker/stiffer
3. Front springs Stiffer Softer
4. Rear springs Softer Stiffer
5. Front wheel camber More positive More negative
6. Rear wheel camber More negative More positive
7. Front tire pressure Lower Higher
8. Rear tire pressure Higher Lower
Deetz.
Deetz.
