can I run 235/40/17's?
Old May 25, 2005 | 07:56 AM
HwangTKD's Avatar
Hey guys,
I have an opportunity to pick up a set of tires that are 235/40/17. are there going to be any problems with this set up? I am on stock rims.
Bobby
Old May 25, 2005 | 08:05 AM
mr_one's Avatar
tire size
i don't know but i have an MR and i am rolling with 245 45 17's
Old May 26, 2005 | 06:06 PM
HwangTKD's Avatar
Anyone?
Old May 26, 2005 | 06:09 PM
ray3328's Avatar
Yes you can use them with no problems.
Old May 26, 2005 | 06:10 PM
Vroompsh's Avatar
You can run those, but your ride will just get rougher and the tires will look small on the rim, when looking at a profile shot of your car. I'm going with 245/40/17's. The reason being is because when you up the width of you tire and keep the same sidewall size the tire tends to look to big for the rim. By getting one size down on the sidewall size (40), i can compensate for this problem. i have a good feeling it'll be nice.
Old May 26, 2005 | 06:12 PM
PVD04's Avatar
The 235/40 17s will work fine. Just remember that your speedometer will be off by a small amount. It will say that you are going slightly faster than you really are, probably ~1-2 mph.
Old May 26, 2005 | 11:18 PM
white05evoVIII's Avatar
you shouldn't have any problems with this setup. the only things that would be different are as said before in previous replies are: a little bit harsher ride and your speedo will be off a tiny bit. but there shouldn't be any others.
Old May 26, 2005 | 11:22 PM
Matthew333's Avatar
no problems, and the speedo wont hardly be noticeable.
mc14
For Sale - Wheels / Tires
Jun 27, 2010 11:43 AM
Loser
Oct 11, 2009 07:47 PM
rmevo9
Sep 15, 2008 06:43 AM
itzcharlez
Jul 29, 2008 02:53 PM
Mr Evolution
May 8, 2006 11:45 AM
