pushing back caliper piston
Old Jun 26, 2005 | 05:49 PM
TrojanMan's Avatar
what do you usually use to push back caliper piston during brake pad install? and for the front where there are 2 pistons on each side, do you need to push them in simultaneously or can you push back one at a time?
thx in advance
Old Jun 26, 2005 | 05:59 PM
JuniorRSX!'s Avatar
I used the brake pad itself that i was replacing... use it like a lever. for the front it goes over both pistons at the same time.
Old Jun 26, 2005 | 06:55 PM
evo81's Avatar
you can push both in at the same time.one at a time works also.you'll get it.very easy stuff
Old Jun 26, 2005 | 06:56 PM
thadon84's Avatar
four hands
Old Jun 26, 2005 | 07:04 PM
TrojanMan's Avatar
thx for the replies. i managed to push them in one at a time with a long screwdriver and rag to cover. needed some pretty good force to push, but it worked.
btw, is it normal to have like a little lip/beveled-edge on that outskirts of the rotor? and are your rotor surfaces pretty smooth or slightly bumpy?
Old Jun 26, 2005 | 09:47 PM
Evo442's Avatar
yes, the "lip/beveled-edge" is normal. The brake pad does not go all the way out to the edge of the rotor. My rotor surfaces were deeply grooved (if thats what you mean by bumpy) after a few days at the track. Just depends on how hard you are on your brakes.
Old Aug 12, 2005 | 09:50 PM
MaxR's Avatar
When I was doing my pads tonight I pushed one piston in and the other extended pretty far. Now it won't go back in. I've put some good force on it but its not moving. Has anyone experienced this before?
Edit: Got it, a break and a new angle worked.
Old Aug 15, 2005 | 11:39 AM
mayhem's Avatar
http://www.zdmak.com/wbstore/main.as...K-BRK-J&CTMP=1
Buy it, use it, love it.
