Wheel Stud Replacement?
Old Jun 26, 2005 | 07:19 PM
Creamo3's Avatar
I did a Search, but couldn't find anything that related to the evo. Does anyone have a quick how-to on how to replace a wheel stud on the rear rotor. I unfortunately stripped one while using an impact gun and need to replace the stripped stud. Any help would be appreciated, also the stud size specs and where to get a new one
Old Jun 27, 2005 | 01:19 AM
3K's Avatar
3K
Just get it from the dealer. It's about $7.00 for the stud. And about $80.00 dollars for the labor if you can't do it yourself.
I would suggest having a wheel shop or the dealer remove the stud for you, because if you strip the side of the stud that goes into the wheel hub, it'll end up costing you about $500.00 in parts and labor to fix that mess. speaking from experience here. Good luck.
Old Jun 27, 2005 | 05:52 AM
Creamo3's Avatar
Thanks for the heads up, I think I will take it to the dealer to get replaced
Old Jun 27, 2005 | 06:09 AM
mdosu's Avatar
I just replaced mine 3 weeks ago. Dealer should have the studs for like $4 each and you probably need order more lugs too...not sure how much it is.
There's a installation how to on this site as well, but I limped it to NTB and had them do it for me...it's like standard everyday fix for those guys or other tire dealerships...dealership might rip you off with labor.
Gtizks
11
Jan 5, 2017 08:11 PM
dcdirtrider
Nov 7, 2016 02:32 PM
balleronabudget
Aug 30, 2015 08:35 AM
ffsman12
May 18, 2015 12:33 PM
Kreeker
May 3, 2015 06:34 PM
