How to get off stuck/broken/stripped manifold studs
Old Apr 14, 2015 | 01:32 PM
ffsman12's Avatar
Hello evo drivers!
Have a question that I've been struggling with...
I decided to replace my leaking exhaust manifold myself, and ran into a few sticky situations... I got all the nuts off except one and had to dremel cut the stripped bolt off...
Now I need to replace the studs for new ones cause during the process of removal one bolt broke off as well as the stud!!!! I have about half a inch of the broken stud still out of the head, tryed to use vice grips and it just would t budge! Suckers stuck
I have another one that is normal length but threads are shot on it so can't so the 2 nut removal trick to that one and tried the vice grips didn't work on either I have sprayed down with pb blast past few days I've shocked them with a hammer to break the bond!!! Any other idea or tips to get off I have a hand torch but the head is aluminum little worried to try that out...
Pls help! Someone I thought might be a few days is taking 2 weeks...and a pocket of change!
Old Apr 14, 2015 | 02:23 PM
sujinX's Avatar
can u remove those duplicate photos? it doesnt seem like its relevant.
you are most likely going to have to drill out the studs unless there are some threads left.
Old Apr 14, 2015 | 02:39 PM
dumpdbasethound's Avatar
I ran into the same problem and nothing would work. Then i found this tool called the titan stud puller and since you have some stud sticking out this should work with some heat. When you you turn this counter clock wise it has these prongs that get tighter and tighter and dig into the stud. It took me ten minutes to get out three broken studs with this, it was a life saver!
heres the link to tool.
http://www.northerntool.com/shop/too...FdgZgQoda6IAIA
Old May 18, 2015 | 12:33 PM
wilownu's Avatar
weld a nut on it and unbolt it like it was a bolt.
95GSXtoEVO8
Feb 21, 2009 02:21 PM
jeffreyinigo
Jul 20, 2008 05:47 PM
spyderx
17
Sep 12, 2006 08:34 AM
walkedu
21
Dec 22, 2005 10:46 AM
dss64bit
Nov 24, 2005 04:26 PM
