Will they Fit?
Old Aug 10, 2005 | 07:10 PM
nolimited76's Avatar
i think i'll fit, I has 245/40 on my 18" works
Old Aug 30, 2005 | 04:22 PM
cocoabro's Avatar
I had 255/40/17 Toyo Proxes on 17x9 FN01R-Cs with just a touch of rubbing in the front passenger wheel well at full wheel lock (car lowered ~1.5" front, .75" rear). I now have Azenis RT-615s in 275/40/17. They've given me some problems (fender rolling, substantially more rubbing up front, ect.), but it's doable. I have some Kuhmo Ecsta V700s coming in the same size, and I'm assuming they'll fit also. The 255/40/17s will be no problem for you.
Old Aug 31, 2005 | 08:07 AM
Driv200's Avatar
I run 275/40 on 9.5" MT03+M Enkei at all FOUR CORNERS!!!!!!!!!!!!!!!!!!!!!!
Had to cut/roll inner rear fenders. Front fenders just pulled out a little.
For you, the 245/45 17's sound like your best bet. But, my set up really is like a hot wheels car on steam roller tires!!!!!!!!!!
Old Aug 31, 2005 | 02:23 PM
cocoabro's Avatar
What did you have to cut? I rolled my rears and still have rubbing where the bumper meets the fender (two corners butted together near the bolt that attaches both pieces together). Is that what you cut? Thanks.
Old Aug 31, 2005 | 02:39 PM
inslowoutfast's Avatar
cocoabro-
I'm looking to get the same 255/40 17 ra1 with fnorc's. Curious about your clearances. What suspension? Stock alignments?
Old Aug 31, 2005 | 02:46 PM
UT_Evo's Avatar
Toyo RA-1s 255/40/17 on my race rims... work just fine, problem is that I've heard they don't heat up quite fast enough for some Autocross events
Old Aug 31, 2005 | 02:50 PM
hagakure's Avatar
Originally Posted by si_eater
i want a 255 slick but kumho v710 doesnt come in that size and the hoosier A3S04 and the A3S05 and the R3S04 dont either
edit: ima retard they do have 255's what they dont have is 40 they have 45
but they do have 275/40/17 i dont know what i would need to do to get those on, or maybe its to much
You can fit 275's with those rims. you need to roll the rear fenders, run the appropriate amount of negative camber int he front, add longer wheels studs with 3 mm spacers.
