ive searched and couldnt seem to find anything. my question is will a 255/45 slick race tire for auto-x\road race fit on a evo lowered with Espelir GT springs with 17x9 5zigen fno1r-c. i cant seem to find the size i use now which is 255/40.
Well I know a 255 is perfect for a 9" rim, so don't see why a 255 slick wouldn't work.
i want a 255 slick but kumho v710 doesnt come in that size and the hoosier A3S04 and the A3S05 and the R3S04 dont either
edit: ima retard they do have 255's what they dont have is 40 they have 45
but they do have 275/40/17 i dont know what i would need to do to get those on, or maybe its to much
245 is a perfect fit for a 9" rim. I have 9x16 on my 911, stock tire is 245/45.
Don't go wider than 255, you'll have excessive sidewall flex that you may not be able to overcome with extra tire pressure
so 245/45/17 is a good size for my 17x9 fno1r-c i want to get the max performance out of my tires i know wider is better to a certain extent.
u can run 275/40/17 V710 on yr 9" wheel, but u will need to run huge negative camber (more than -3), 10+mm spacers and rolled fender for the front, not sure about 275 V710 on the rear though, but 275/40/17 victoracer fit the rear with just rolled R/Fender. hope this help
i reaqlly dont want to run that much negative camber, its my daily driver and dont want to roll the fenders, ^^^what are anybodies thoughts on the 245/45
i currently run 255/40/17 victoracer -3.6F/-1.5R camber on 9" wheel have no problem, but half of wear on this tires were running less negative camber (max out stock suspenion to -1.6F/-0.8R), so these tires wore much faster than what they suppose to, same like you, i don't wanna roll my fenders, so i just ordered a set of 245/45 V710, and i sure have NP for clearance, but i still suggest you run more negtive camber to save your tires.
on my race rims im runninig 255/40/17 falken azenis rt-615
and i want to try a slick tire but like i said kumho and hoosier dont have that size
what about 255/45 is that to tall , if it is i may just go with 245/45
oh yeah these tires wont be used daily i have my stock rims with all seasons
as the money and the fender issue, i went with 245/45 V710, i think it's better than 255/40 victoracer as the width spec is not much diff. and u sure got much better performance
I recommand Kumho Victoracer and Toyo RA1 which offers the size you want (255/40/17). I don't know who makes 255 45 17 but they are too tall anyway. if you want to run 710 or hoosiers, you can run 245 45 17. They are just as wide as the victor or toyo 255 but a bit taller. Be warn that they wear out FAST!
BTW, all the above tires are R compounds DOT tires. NOT slicks.
Quote:
yeah thats what i meantOriginally Posted by kevo
, im new to auto-x and friend of mine told me to go r-comp so i could get faster timesthese arent goin to be used daily
