Mitsu wants $800 for pads and install.
Originally Posted by Greg K
actually a rally car's brakes tend to get hot and stay hot from prolonged left foot breaking. I'd be willing to bet that my average break temperature is significantly higher than you'd see on a track only car.
Emre
Ive got projectU pads on mine and intalled them my self. 1yr and 1 Nurburgring trip later still got lots of meat left. IMO your gonna get opinions from all pads good or bad. Your just gonna have to jump out and try some.
Originally Posted by mooreboost
I was pretty sure I was going to do that but the guy at Mitsu said he would cut my rotors while doing the job. Is that required?
Originally Posted by glgz
Does that $800 include dinner as well? I mean if your getting f&cked that bad they might as well buy you dinner first.
That along with a full tank of gas and a paid lap dance (with beautiful lady of course)
You can do the pad change in < 2 hr. Good luck.
My local Mitsu dealer wants $800 bucks to do pads front and rear. I told him I would just bring him aftermarket pads and he said he couldn't do that.
Ridiculous.
I'm back to finding aftermarket pads and a new installer.
Suggestions?
Ridiculous.
Suggestions?
There is a guy locally who had his pads replaced at a local dealership for an outrageous amount, he ended up having bad squeeking a few days after, they hadn't even lubed the sides of the pads. Do it yourself, and if your not sure I'm sure one of the guys local to you will be willing to help out. Its an easy job.
If your rotors are warped, I'd get a set of replacement rotors from rotorpros (get the blanks, not slotted/dimpled -> ok, if you have to, get slotted but not dimpled
, and get them unpainted). If you get the stock rotors cut, yes they will last a little while longer, but when you start cutting (turning) them, they will just warp that much faster.Total bill for a complete brake overhaul should look something like:
~$200 - Hawk HPS front and rear pads (assuming street use here)
~$300 - Rotorpro front and rear rotors
~$ 32 - Motul RBF 600 brake fluid (two containers) to flush your brake system
~$ 10 - miscellaneous stuff (i.e. clear hose to drain BF, breaker bolt for rotors, etc.)
~$542 + one afternoon in your garage = complete brake job on your Evo ... all shiny new parts
l8r)
Originally Posted by Ludikraut
DIY all the way. Here's how I did it: https://www.evolutionm.net/forums/sh...8&postcount=42
l8r)
l8r)
I got the same rotors (dimple and slotted) but haven't put them on yet. I don't think you can get them for $300 anymore. How are the rotors holding up? I hope they will be okay for street use and occcasional track. Hope the wheels won't start to shake after a bit too
When you install the slotted rotors, it seems that they pickup less brake dust if the slots don't turn into the pads, and with the rotorpros either direction does work, since the internal vanes on the rotors are not directional.
l8r)
