Staggered Wheels
Old Sep 10, 2005 | 11:51 AM
en1gma19's Avatar
FWIW, Porsche uses a staggered setup on the 911 C4 and 911 Turbo which are both AWD, but the Gallardo that someone mentioned earlier is RWD, Murcielago is AWD. Skyline uses a staggered setup. It's actually not uncommon.
Old Sep 10, 2005 | 11:52 AM
dadriva's Avatar
^ well put!
Old Sep 10, 2005 | 11:54 AM
AWDrift07's Avatar
Originally Posted by dadriva
I suppose I would say your 03 Evo isn't wrecked....it is operationally challenged (bummer by the way, I'll bet you miss it)
yea and the driver who hit me and almost killed me wasn't drunk he was just operationally challenged... thats funny
Old Sep 10, 2005 | 11:56 AM
dadriva's Avatar
Youch, sorry if I touched on a sore subject for you.
Old Sep 10, 2005 | 02:21 PM
hueman's Avatar
Originally Posted by AWDrift07
Wow that's a very optimistic interpretation! I may have failed to read between the lines on his post but most people would agree that when he said "staggering won't make a difference in AWD systems" what he really meant was that staggering won't make a difference in AWD systems. Maybe i'm just taking things too literally but it was pretty cut and dry to me.
When you lose do you call it not winning?
i'm pretty sure he was talking about hurting the awd system, not the performance aspect. he's saying the rolling diameter is what is under discussion here (in reply to my somewhat offtopic post before his), not the width, which he realizes won't hurt the driveline.
Old Sep 10, 2005 | 02:25 PM
hueman's Avatar
they use a much different version of awd don't they? i thought they were rear wheel drive till their ecu tells them to use their front wheels compared to our full-time awd drivelines which only shuttle tq temporarily
Old Sep 10, 2005 | 02:33 PM
Evo_SpeedKing's Avatar
if you go back to Sept 02 (vol 14, no. 9) of Sport Compact Car, the Bozz Speed EVO VI has Volk SE37K's 17X9.5 (fronts) & 17x8.5 (rears) using 255/40zr17 rubber all around. this was at the suggestion of Rays Engineering to square off the front tire sidewall and "round" the rear side wall. this set-up offered higher grip up front and more breakaway from the rear.
Old Sep 10, 2005 | 02:38 PM
smack_evo's Avatar
for what it's worth, i read it the same way as the other guys.
that the stager has nothing to do with awd problems and only diameter is the real issue here.
but this is talking about awd diff issues not handling.
Old Sep 10, 2005 | 03:04 PM
go_evo_go's Avatar
solid points it would be cool to see on an evo. I love the staggered look.
Old Sep 10, 2005 | 03:09 PM
Gruppe-S's Avatar
it all depends on the design of the awd system. EVOs drivetrain is more FWD biased (I think its 60/40 torque split but i can be wrong here.), so a lot of JDM tuners use wider width up front than rear. Just like what EVO Speedking quoted, ".... to square off the front tire sidewall and "round" the rear side wall. this set-up offered higher grip up front and more breakaway from the rear."
Cal
Old Sep 10, 2005 | 03:14 PM
go_evo_go's Avatar
so would the rear wheel staggered look be more for show or should you just stay away from it all together.(rear wheel)
Old Sep 10, 2005 | 03:17 PM
Gruppe-S's Avatar
if u go w/ wider rim in rear, and skinnier rim up front, it will throw off handling quite a bit.
TheGVR4kid's Avatar
Really it's all just going to come down to driving style and course layout. Most of those Japanese tracks are very small and very tight, a simple staggering of the wheels is going to give you a small contact patch in the rear with less of a shoulder to roll over onto, basically you're going to have less grip in the rear and allow the car to rotate. It's a lot easier and simpler than proper suspension tuning and probably for a lot of the guys in Japan, it's a final option when everything else fails.
Unless you're an autocrosser who has exhausted their suspension tuning options and is still having trouble pushing in the tight stuff, I don't see any reason to go staggered....well unless you're mAd tYtE jDm d0rIfTo kInG.
Old Sep 10, 2005 | 03:36 PM
hueman's Avatar
i dunno, i think there's something to be said for the weight biased front getting larger contact area.
Old Sep 10, 2005 | 11:12 PM
BlewBuYou66's Avatar
I just put a set of Work wheels on my rig that give a staggered appearance. They are same size and offset front and rear. 18x8.5 +29 but have a "type R" front disk and "type O" rear disk. This gives a nice dish in the rear. I have pics but cannot figure out how to resize and post on here. If someone would like to host them That would be cool.
can someone please host these pics so that we can see them!!! thanks
