steering wheel vibration when braking
Old Sep 30, 2005 | 03:38 PM
03SilvaEvo's Avatar
I noticed when I brake(not hard though) I feel the steering wheel vibrate a little. This happens only when I'm stopping from 100 mph. Lower than that I get no vibration. Is it normal for the steering wheel to vibrate when braking from triple digit speeds?
Old Sep 30, 2005 | 03:41 PM
hphan's Avatar
If your car/steering wheel shakes or shimmys when braking at high speeds it's 99% attributed to your uneven rotors. Have your rotors resurfaced or replaced if the rotor is too thin.
Old Sep 30, 2005 | 03:43 PM
Randman's Avatar
Just wondering how many miles are on your evo just so I can guess when to expect this problem.
Old Sep 30, 2005 | 03:45 PM
GinuwineEvo8's Avatar
Try doing a couple (3-5) 70-10 mph HARD STOPS ... its not nessicarly warped rotors ... More of pad buildup if your driving gimpie ..
P.S. Do a search - its been covered ;D
Old Sep 30, 2005 | 04:07 PM
03SilvaEvo's Avatar
The car has 14k miles(9600 when I got it) now. Still stock pads and rotors.
Old Sep 30, 2005 | 09:44 PM
AllYouCanTiff's Avatar
from my experience its warped rotors but 14k miles? the other guy might be right.
Old Sep 30, 2005 | 09:49 PM
rExTuHfEr's Avatar
your rotors are not good.
Old Sep 30, 2005 | 10:10 PM
KevCon's Avatar
Don't be so quick to blame the rotors---it well may be the rotors, but it can also be a wheel slightly out of balance (front wheel, BTW). You may not notice the slight vibration in the wheel at higher speeds until it is exacerbated under braking. I have had both problems, and trust me, it was difficult to tell the difference.
Old Sep 30, 2005 | 10:47 PM
ez's Avatar
ez
Significant rotor runout or thickness variation would likely cause a noticeable vibration at lower speeds as well. I'm leaning toward a balance issue as well...although just about anything is possible.
Old Oct 1, 2005 | 02:13 AM
Addicted4Life's Avatar
You're lugnuts may have been torqued incorrectly. Check torque all around. You'll probably have to have the rotors turned, but the problem shouldn't come back if the wheels are balanced and torqued,
Old Oct 1, 2005 | 02:24 AM
Evo442's Avatar
This is not an uncommon problem with the evo's. You'll see posts about it from time to time. I have problems like that after track days sometimes. May be uneven buildup of pad material on your rotors. Rebed your pads, that fixes the problem for me. Check out the stoptech link below. has some good info.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Oct 1, 2005 | 05:13 AM
Chamama's Avatar
I have had the same problem with another car of mine, also @ 18k km. It was vibrating if braking from above 100km/h. Brake pads were inspected and didnt seem too worn out. Didnt know what had happened, so I did the following and the car was as good as new:
1) Brake disk turning
2) Brake pad change
3) Wheel Alignment
Old Oct 16, 2005 | 09:53 PM
scb1999's Avatar
I had the same problem at 6k. My local dealer resurfaced the rotors @no cost. The odd thing the mechanic didn't do anything with my pads. He said they were fine and had 95% of thickness left. So far, so good.
Old Oct 17, 2005 | 06:52 AM
Jeller's Avatar
This is a great read, More people should read this, very informative
Old Oct 17, 2005 | 06:59 AM
TxEvo8's Avatar
+1 on the pad deposits. You need to get wheels balanced and check the lugs with the car in the air. The rotors are not bolted to the hub, the lug nuts hold them on, so use a torque wrench and torque to 90 lbs.
