Hotchkis Front Spring Question
Old Oct 1, 2005 | 08:37 AM
fixem2's Avatar
When looking at the Hotchkis front springs there is very little progression in the spring. To the point that I can't tell which end of the spring is the bottom. Has anyone who has installed these figured it out. I know they are stamped with the Hotchkis name and lot #, but I am not sure if I can use that as an install guide. FOr example, install with Hotchkis right side up or upside down.
Any help is appreciated.
Old Oct 3, 2005 | 09:24 AM
fixem2's Avatar
bump
Old Oct 3, 2005 | 09:34 AM
BLKWIDO's Avatar
I have mine label facing up, very important make sure strut is align. im sure the instructions tell you how.
Old Oct 3, 2005 | 10:52 AM
fixem2's Avatar
I mad sure the strut was aligned, but It was rather difficult to determine what end of the spring was progressive. The progression is very small on the fronts. My label is facing upside down on both fronts.
Old Oct 4, 2005 | 03:47 PM
fixem2's Avatar
Here is the answer to my question from Hotchkis :
The tighter coils should be toward the top. Usually you should be able
to read the part # right side up.
Drew Oliver
Sales/Tech.
Hotchkis LLP.
Looks like I need to reverse my fronts!! Grrrrr.....
Old Oct 4, 2005 | 03:58 PM
evo_rc's Avatar
i had the same problem with my tanabe gf210 I was confused by the instruction, do not go with the label cause it could be upside down when u place
the spring. Make sure u place the spring where the top is more narrow and it gets wider on the bottom.
Old Oct 4, 2005 | 04:04 PM
EvoG8r's Avatar
Now I'm gonna have to check mine. I think mine are right, but to be safe...
Old Oct 4, 2005 | 08:03 PM
fixem2's Avatar
The Hotchkis front springs are progressive, but barely. It is very tough to tell which end is the progressive end.
Old Oct 6, 2005 | 06:39 PM
EvoVIII_SFL's Avatar
I just checked mine and couldnt really tell.
does anyone know if the ride will be different if they are reversed? I mean obviously, but.. how so?
