Slight problems with Cusco bar - Help!!
Old Nov 8, 2005 | 05:17 PM
mdosu's Avatar
Exclamation Slight problems with Cusco bar - Help!!
I've had the Cusco OS rear strut bar installed for the last 4 months with no problems, I've never adjusted it out of the box and had properly torqued it down on the strut towers according to specs.
Problem: the middle aluminum section piece rattles when I hit a bump...though its not consistant. Playing with it with my hand, I can shift it sligthly vertically and cause this rattle sound as well, but it would not move at all horizontally. (makes sense since it appears the two end screws appear to allow the adjustment vertically)
I didn't try too hard, but it doesn't appear I can adjust the two end screws any more either. Neither do I want to, since it is factory specs.
Questions:
1. have you had this problem?
2. Is it okay to adjust those two screws? Should I?
3. If I turn the blind eye, does this diminish the effects of the bar?
also I just noticed this problem after this weekend's sprited drive in the hills around here - pushing the car to understeer/oversteer conditions...so yes I was pushing the limits of the car.
Old Nov 8, 2005 | 10:09 PM
forum04pl's Avatar
you need to tighten that bar down, there is a bolt on each side of the bar that connects to the strut tower mounts it should be an allen wrench to tighten it
Old Nov 9, 2005 | 05:34 AM
Z1 Performance's Avatar
they should always be tightened upon install - no need to get all **** with torque specs, etc, just till it's snug is fine.
Old Nov 9, 2005 | 07:34 AM
mdosu's Avatar
^^ so are you suggesting I should tighten the centerpiece more than? apparently something did jar it lose last weekend.
Old Nov 9, 2005 | 07:40 AM
when the bars ship from Cusco, they are snug, but not as tight as they could be. This is so they can bend one of the brackets forward and fit it into the box. Tightening it is very simple - there is an large-ish allen bolt on one side, and a nut with washer on the other side. Use a 3/8 wratchet, or a wratcheting open end wrenche on the bolt, and the appropriate sized allen key, and snug it all down and you'll be good to go
Old Nov 9, 2005 | 07:41 AM
mdosu's Avatar
thanks! I'll give a try after work today.
djdnav
Aug 23, 2014 07:22 PM
CFar
Evo X How Tos / Installations
Mar 21, 2010 01:44 PM
avengerhed
Mar 27, 2007 07:41 PM
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
129
Sep 30, 2005 01:31 PM
sleet
Dec 12, 2004 03:31 PM
