Torque on coilover install...
Old Nov 26, 2005 | 05:42 AM
techause's Avatar
I searched, but the only thread w/potential info has a link to socalevo.net... which is down. Does any one have the torque specs for the bolts on this install.... ie.top(mounts) and bottom of coilover?
Any help would be appreciated.
Old Nov 26, 2005 | 08:15 AM
Noob4life's Avatar
Go with stock specs if you have them handy. If you don't, do not over-tighten. While you don't want it too loose, tighten it reasonably and don't go overboard.
Old Nov 26, 2005 | 09:22 AM
techause's Avatar
I am looking for the stock specs if anyone has them.
Thanks again!
Old Nov 26, 2005 | 09:34 AM
96_LXR's Avatar
Here ya go, this is from the '03 CD manual . . .
FASTENER TIGHTENING SPECIFICATIONS M1332008500197
ITEM SPECIFICATION
Front axle crossmember bar
Front axle crossmember bar bolt 49 ± 10 N·m (37 ± 7 ft-lb)
Lower arm assembly
Lower arm to crossmember connection bolt (Rear) 167 ± 9 N·m (123 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Front) 186 ± 10 N·m (138 ± 7 ft-lb)
Lower arm to knuckle connection nut 108 ± 10 N·m (80 ± 7 ft-lb)
Stabilizer bar
Crossmember to body connection bolt and nut 167 ± 9 N·m (123 ± 7 ft-lb)
Crossmember bolt 49 ± 10 N·m (37 ± 7 ft-lb)
Rear roll stopper connection nut 52 ± 7 N·m (39 ± 5 ft-lb)
Stabilizer bar bracket bolt 39 ± 5 N·m (29 ± 3 ft-lb)
Stabilizer bracket bolt 21 ± 4 N·m (16 ± 2 ft-lb)
Steering gear and joint connecting bolt 18 ± 2 N·m (13 ± 2 ft-lb)
Tie rod end to knuckle connection nut 25 ± 5 N·m (19 ± 3 ft-lb)
SPECIFICATIONS
FRONT SUSPENSION 33A-24
Strut assembly
Strut nut (self-locking nut) 60 ± 10 N·m (48 ± 4 ft-lb)
Strut assembly to body connection nut 44 ± 5 N·m (33 ± 3 ft-lb)
Strut assembly to knuckle connection nut 167 ± 9 N·m (123 ± 7 ft-lb)
Old Nov 26, 2005 | 10:27 AM
techause's Avatar
Thanks!!!
joseph_mills
Evo X How Tos / Installations
17
May 16, 2019 03:24 PM
Wanted EVO IX
Feb 27, 2017 12:02 AM
mrdecibel
May 17, 2008 05:20 PM
MrEvoVIII
May 23, 2006 08:45 PM
Sten
Jul 7, 2003 03:30 AM
