Minimum Temperature for Stock Tires
Originally Posted by EvoRSfor060
At what temperature do you swap the stock Advans for a winter / all season solution? 50F? 40F? 30F?
Obviously you want to swap them when snow is on the ground. When the temperature gets cold enough the material properties of the rubber compound change. So even if it's cold and dry the Advans will still give weak performance. Like driveing on roller skates.
onyx1121
Oct 27, 2009 08:29 AM
Alex Rodriguez
Jan 25, 2009 05:37 PM
