Alignment Settings??
Hey guys I just got my car aligned and I just wanted to report the settings that he set the suspension at.
I have the Tein FLEX system with stock rims and tires are falken ziez512 I believe. Same size as stock...
Front Camber:
Before: L=1 3/4 R=1 1/2
After: L=1/4 R=1/2
Rear Camber:
Before: L=1 1/2 R=1 3/4
After: L=1 R=1
Toe Front:
Before: 1/4 IN
After: 0
Toe Rear:
Before: 1/4 IN
After: 0
These setting are for normal daily driving with no road coarse and some drag time..
Thanks for the advice/input
Front Camber:
After: L=1/4 R=1/2
Rear Camber:
After: L=1 R=1
Toe Front:
Before: 1/4 IN
After: 0
Toe Rear:
Before: 1/4 IN
After: 0
After the installation of the suspension techniques rear sway bar, the rear was out slightly. So that was taken back to spec and the front was right on.
He did say that the steering was a little loose, so he tightened that up....after these small adjustments, the car is much tighter feeling...
I would have gone (and this is my setup):
-2 front, -1 rear, 0 toe f/r, max caster (little over 3 deg)
And my car is d/d, tracked, and drag
goofygrin
88
Jul 24, 2022 08:22 PM
idriveanevo
11
Jun 16, 2009 09:45 AM
AhmadHasib
14
Apr 12, 2007 07:19 PM
honda-guy
Oct 11, 2006 05:10 AM
